[v51] bug info after resize
Kadet
Post by Kadet »
If I convert a file, e.g. png, to another format, e.g. jxl, and then reduce the same png file by e.g. 50% and save it as jxl with the same name, I will see the unchanged size. Cleaning the database restores the correct x/y size information of the reduced photo.
Re: [v51] bug info after resize
you means the pixel size in labels?
Kadet
Post by Kadet »
xnview wrote: Thu Sep 10, 2026 6:16 am you means the pixel size in labels?
Yes. And in Photo details.
you convert the file from browser?
Kadet
Post by Kadet »
xnview wrote: Thu Sep 10, 2026 3:28 pm you convert the file from browser?
It didn't matter where I did it from.
sorry but not able to reproduce. Please send screenshots to reproduce?
