Companion Files help
dave80
Post by dave80 »
One of the default Companion file settings is Master={raw}, Companion=jpg.
If I switch the values so that Master=jpg, Companion={raw} it does not work. Why not?
What setting can be used to make jpg the Master and raw the Companion without having to list all raw formats separately?
Re: Companion Files help
I can confirm
there are several issues with Association list that need to be fixed
related
1.11.2 - settings - companion - Association list ignored
dave80
Post by dave80 »
user0 wrote: Thu Sep 10, 2026 5:15 am I can confirm
related
Hi, thank you. I will try it with a list of raw extension then to see if I can get it to work that way. If it does not work I will submit a bug report.
EDIT: I have made a small list of my most used raw file extensions and it appears to be working.
