1.11.6 File selection gets reset when closing Settings
deil
Post by deil »
XnView: MP 1.11.6 64 bit
OS: Windows 10Pro 22H2 64bit
Effect: When in Browser mode, after closing the "Settings" window, the selected file/folder is not selected anymore, and the browser is scrolled to the top. Nothing is selected, and if I press Left on the keyboard, the cursor starts moving from the first file in the current folder.
That's especially painful in big folders, and you lose the position somewhere in the middle of thousand files. This behavior only started somewhere around 1.11.x version, can't say when exactly, sorry, but I'm almost sure it used to be as described in "Expected behaviour".
1. Open folder with a lot of files, so there's a scroll bar.
2. Scroll somewhere down and click once on any file to select it.
3. Press F12 to open Settings.
4. Close Settings, with either Ok or Cancel button.
Actual behaviour (bug): No file in browser is selected anymore, and the browser is scrolled to the very top.
Expected behaviour: The file that was selected before Settings window was opened is still selected, and the scroll position is unchanged.
Re: 1.11.6 File selection gets reset when closing Settings
:bugconfirmed:
peterfalk
Post by peterfalk »
deil wrote: Thu Sep 10, 2026 7:45 pm To reproduce:
It does not depend on the setting window. It happends also when you have selected a file in the browser view and simply add a file to the folder for example through Windows explorer. The browser in Xnviemp jumps to the back to the first file and selecting it.
This is on 1.11.7. and we need a fix for the 11 version as we cannot switch to 12.
