Modernize QFileDialog filter strings for Linux XDG Desktop Portal / Flatpak support
BloodySword
Post by BloodySword »
Hi Pierre,
When running XnView MP on modern Linux desktop environments (in my case under Flatpak / Wayland / KDE Plasma 6.7.5 on Fedora 44), enabling system file dialogs (XDG_PORTAL / QXdgDesktopPortalFileDialog) causes file-saving to fail.
Issue
The xdg-desktop-portal service cannot parse XnView MP's current QFileDialog filter strings (it returns empty () extension fields to the portal), which breaks MIME type detection and prevents image writing modules (e.g., PNG/JPEG) from initializing on save.
Request / Proposed Solution
  • Standardize Filter Strings: Ensure QFileDialog invocations on Linux use standard Qt formatting (e.g., PNG image (*.png) or QMimeDatabase MIME-based filtering) so QXdgDesktopPortalFileDialog can map them to system portals.
  • Native Dialog Flag: Make sure the QFileDialog::DontUseNativeDialog is not hardcoded on Linux builds when the user checks "Use system file dialog".
  • Optional Build/Compiler Flag: If necessary, expose a build flag/macro for Linux releases so native portal dialogs work out-of-the-box in Flatpak packages.
This would eliminate the need for workaround tools like qt5ct or fallback GTK themes when running XnView MP in sandboxed or Wayland environments.
Thank you for your hard work on XnView MP!
Re: Modernize QFileDialog filter strings for Linux XDG Desktop Portal / Flatpak support
Sorry but i've tried latest version (flatpak) on Fedora 44/KDE, but i can't see problem in file dialog
BloodySword
Hi Pierre,
it's because I have informed Flathub about this as well to find a better workaround.
https://github.com/flathub/com.xnview.X ... issues/118
Since this is only a workaround for now, I think it would be better to implement this in the correct way.
On my side I set QT_QPA_PLATFORMTHEME=qt5ct and used the QT5 settings app to set the dialogs to gtk3. But the preferred method (of freedestkop.org) is to now use the XDG_PORTAL and it needs a different format for providing the file type selection.
This might break in the future again.
