New icon for XnView
Moderators: XnTriq, xnview
ckit
Post by ckit »
I'm with Helmut, we need to hijack the icons from XnView Deluxe.
Crysler
Post by Crysler »
ckit wrote:I'm with Helmut, we need to hijack the icons from XnView Deluxe.
Seconded
robc
Post by robc »
ckv wrote:XnView 1.82.1 is out and it haves a new main icon, but the 16x16 256 color icon looks piece of s*! :P
And once again I am forced to use my super powers and make a new shiny icon. *cough* arrogant bastard *cough* :mrgreen:
On the left is 1.82.1 and on the right is my creation
ckv, I don't understand, this is the icon I get in 1.82.1 :shock: which I do like... are you running windows with just an 8bit color depth?
ckv
Post by ckv »
robc wrote:ckv, I don't understand, this is the icon I get in 1.82.1 :shock: which I do like...
Have you ever hear about XP icons?
I don't have XP so I don't get to joy those alpha blended true color XP eye candy icons. :) You have XP and therefore you don't get the icon what I see. I thought that you know these things. :|
robc wrote:are you running windows with just an 8bit color depth?
No. Icons can have multiple color palettes. And those who don't have XP, will see the the true color or 256 color version of the icon and since since 16x16 icons haves only 256 (16*16=256) pixel in them, there's no point to make 16x16 true color icon.
robc
Post by robc »
I know that, ckv, I just supposed Pierre DIDN'T use alpha-blended icons since he said they didn't look good under W2K (of course)... I was mistaken.
Moderator & Librarian
robc ([url=http://newsgroup.xnview.com/viewtopic.php?p=25071#25071]05/Feb/2006[/url]) wrote:[...] For the above reasons, sometimes (I remember noticing it several times) the 16x16 icon is altogether different from the 32x32 and up, since in many cases just reducing the bigger image yields disastrous results... If the deLuxe icon (which I had never seen) is going to be used, that's fine, it looks nice to me: we just need to find out if it scales down well and can be made transparent (I assume the whitespace behind it is transparent in the sample you provided), otherwise we need to design a simpler image, just for the 16x16 format. I believe whoever designed the deLuxe icon is perfectly able to come out with a nice, transparent 16x16 image suitable to be used as the main application icon.
The following icons were extracted from “XnViewMediaDetector.exe”, which is part of XnView Deluxe 2. For convenience, I provide examples with different shades of background color: transparent, #ffffff (white), #d4d0c8 (light gray), #808080 (dark gray), #000000 (black).
Click to enlarge (60K)
To be honest I'm a bit surprised to see a new icon in XnView 1.82. Perhaps I should have payed more attention to this discussion.
The new icon is o.k., though it looks very fragile. I think it should be a bit bolder. Also the orange looks a bit dirty and could be a bit fresher. The overall result is good, the "finishing" is a case for a real designer, I think.
Dreamer
Post by Dreamer »
helmut wrote:To be honest I'm a bit surprised to see a new icon in XnView 1.82. Perhaps I should have payed more attention to this discussion.
Yes. Larger icons are not the best too...
The large icon (32x32) icon is the one I refered to in my above post. The 16x16 icon is just a bit blur, the rest is o.k..
robc
Post by robc »
I definitely support the DeLuxe iconset, though I'm already satisfied with the current 1.82 icon.
Another problem of the new, small icon:
On Windows 2000 the icon is very hard to see in the grey menus.
(Sorry for critisizing, again, but I really think the new icon has been introduced too early).
ckv
Post by ckv »
helmut wrote:Another problem of the new, small icon:
I understand. The icon should be darker, but not much.
What you think? (lowest is current)
ckv wrote:...
Exactly.
ckv wrote:What you think? (lowest is current)
Much better. :-) Personally I'd go for the second from bottom. The one at the top is too dark.
Dreamer
Post by Dreamer »
Nice, I like the second from the top. The second from bottom is still a bit unclear on grey background.
ckit
Post by ckit »
I agree, we need a icon that is clear for grey backgrounds.
