Review XN mobile Android - first impressions, one request
Kai Schwarze
Post by Kai Schwarze »
Device: Google Pixel 9a, Android version 17
Today i started with XN-View for Android. Mostly i think it is great, but one and two half disturbences i did find:
Installation process without any problems
Almost the first start of the app ist remarkable quick.
First view is in Albums in the DCIM folder. My 18 subfolders are all displayed correctly. Well done! Folder name und number of files are shown. Great!
What is missed? A menu concerning the complete folders with tasks like rename, delete, move, copy, sent ….
After opening a folder (=Album) I tap on an image and have a full-screen view with some meta-informations. Nice! But no option to hide these infos. Could be nice, to see just the picture on black background.
Double tap opens max zoom, second double tap leads back to full image view. Clever!
Swiping upwards gives the full range of meta informations, wow! Swiping downwards gives … nothing. Ups. This downswipe should lead back to the previous situation (full-screen-view)
the „…“ dropdown menu has everything what is with sense imaginable. Painting and marking works great, saving is possible without any troble.
So on the whole: You folks did make a great job! Congraulations!! :D
So, please think about the „downswipe“ and my be it could be an idea to have optional pop-up hints, what can be done, how does it work, that will help new users.
But probably, there are only two types of users – those who work and think by themselves - these will find out the „how-to“ easily – and the other 3 quarters of mankind how say, why the hell shall i think with my brain, if i could have an AI-solution …. senseless, to give them hints.
Sincerly – yours Kai
Re: Review XN mobile Android - first impressions, one request
Kai Schwarze wrote: Tue Sep 29, 2026 1:01 pm What is missed? A menu concerning the complete folders with tasks like rename, delete, move, copy, sent ….
Sorry but what do you means? you have the menu when you select some files
A long tap show/hide overlay
currently it's a tap that returns to fullscreen, but i'll check to have it too
Thanks!
I need to think about it
Kai Schwarze
xnview wrote: Tue Sep 29, 2026 1:10 pm
What I mean ist a menu related to a complete folder. Not the files inside the folder.
For example, if woluld like to delete a complete folder. Or rename the folder. Or sent / share a complete folder with somebody else. I hope, i could explain, what i meant.
A long tap show/hide overlay -
Ah, got it! Good idea. Just not obviously ... may be: An icon at the right side of the screen is easier to find?
Tap is a possibel solution, but not the logic way ... swiping in and tapping out is like getting in through the door and leaving through the window. Same way in and out is in my opinion more logic.
Thanks!
...it is said with pleasure!
Kai Schwarze
some more aspects:
Something else:
If I open the details from a picture i see only a image section. I can't enlarge or shrink this section. I would prefer to see teh overview/complete image. or even better, have the possibility to enlarge / shrink the section.
Why? I often take some pictures from slightly different viewpoints or with differing focus. If I see only a section, i don't know, which picture out of this series i do see actually.
This ocures much more, if I use XN mobile with a tablet (Android).
An other point using a tablet is, that the size of folders should be flexible. In landscape format we have only three folders in line - but only two rows to be seen. On a smartphone screen ok, but on a 10" tablet screen not so awsame.
Yes - and i found my answere almost myself: - using "style" i can change the number of folders per line. It is a little bit hidden. I would suggest to put this feature some more in the "front".
I hope, these ideas help yo to continue making XN- viewer for Adroid to the best Android viewer of all!
B.Douille
Post by B.Douille »
I agree, though of it for some time as a more logical gesture to leave the detail view.
Agreed as well, already requested here viewtopic.php?p=217380#p217380
Daniel, happy user for 20 years, to manage photo and videos and share them in slideshows (Windows 11, Linux Ubuntu and Android)
Kai Schwarze wrote: Tue Sep 29, 2026 8:40 pm A long tap show/hide overlay -
I've added an information
Please check v70
you have Settings>Display>Fit in v70
yes, you can configure. but perhaps a better default when you are on tablet??
B.Douille
Post by B.Douille »
I think the option should be activated by default.
Once activated it allows to see the pictures in full, whatever the ratio.
However we loose the easyness to compare the data line-by-line by sweeping left-right when the ratios are different. I think we discussed this issue some time ago. As mentioned before, I recently suggested to use a design like in the Draw tool. The image sits in a square of fixed size.
B.Douille wrote: Wed Sep 30, 2026 9:17 pm
please check v71
B.Douille
Post by B.Douille »
Now we see the pictures in full, whatever the size, the ratio. Great. Thank you for responsiveness.
I think this option can be removed. Useless as a view with pictures half-zoomed, truncated doesn't help as Kai said.
And this is fixed as well:
B.Douille
Post by B.Douille »
Option still in v72, and set to Off. I don't believe that users are going to think of an option somewhere in the settings. Personally I would never seek for.
Testing further I see the image for videos doesn't sits in a square of fixed size as for photos.
