Batch rename systematically generates a crash of XnviewMP when using "replace" with a new name that is made of 2 or more words separated by a blank. This may happen, but not systematically, when the new name is a single word, and so far it does not happens when using "name template"
thanks
simon
1.12 on windows 11: big issue with batch rename
simon
Re: 1.12 on windows 11: big issue with batch rename
do you have sent the crash dump? please show the dialog used?
simon
I have just do again the procedure and sent the report
