1.12.1: Thumbnail view very slow after update
Akovia
Post by Akovia »
XnView: xnviewmp 1.12.1-2 (+329 1.10) - 64bit
OS: Linux - 64bit
After updating system, it takes between 5-30 seconds to draw thumbs in a directory.
Effect: Program hangs
1. Open xnviewmp
Actual behaviour (bug): Program hangs while loading thumbs :bug:
Expected behaviour: Draws thumbs fast as it always has.
The errors i see are:
qt.multimedia.playbackengine.codec: "No HW decoder found"
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
BLOB length 75
## updateCount ===>   14ms (6)
## updateCount ===>   23ms (10)
## updateCount ===>   23ms (26)
## updateCount ===>   23ms ok
dataChanged() called with an invalid index range:
    topleft: QModelIndex(-1,-1,0x0,QObject(0x0))
    bottomRight:QModelIndex(-1,-1,0x0,QObject(0x0))
I still have one of the nightlies installed and it was affected in the same way.
Edit: After being open for a while, it seems to get back to normal speed, but on first opening xnviewmp, it actually hangs the program enough that the colors fade out like it's about to get a kde system message that the program is not responding, but finally catches up.
Arch Linux
XnView MP
Re: 1.12.1: Thumbnail view very slow after update
Always the problem? Do you have video file?
Akovia
Post by Akovia »
Videos weren't the issue, but I couldn't figure out what exactly was causing it.
I decided to wait to see if another system update fixed it and it appears to have worked so far. I'll report here if it starts happening again, but hopefully this solved..
Thanks!
Arch Linux
XnView MP
