Is there a max thumbnail database size? I never had this issue but starting recently, the software fails to add new generated thumbnail to the database, which cause issue for putting files into different categories.
i tried making a new database by changing the folder location of the db in the settings and everything worked fine, then i reload my main db and the issue persists.
my db is quite large, over 40gb, is there a setting somewhere that limit its size?
edit: folders are not excluded
Fail to add new thumbnail to database
Re: Fail to add new thumbnail to database.
there is no point in having a 40 GB thumbnail database
1. make backup of XnView.db
2. run Maintenance with first 5 checkboxes checked
in Settings>Catalog>Maintenance
minmax
I thought i had to keep the thumbnail db to have all my categories intact but instead i just kept the XnView.db and made a new thumbnail.db and works perfect now, thanks.user0 wrote: Mon Oct 05, 2026 4:39 am there is no point in having a 40 GB thumbnail database
