I’m using Windows 11, and the software is the portable version.
As the title says, when batch renaming files, a rename preview appears on the right side.
However, this doesn’t seem to work for folders.
I would appreciate any advice. Thank you.
1.12.1 How to batch rename folders, not files?
votary
