v1.12.1 Inconsistent Font Size
alee001
Post by alee001 »
After the update, I found that the overall font size is larger and easier to read (I like it) :D , but the font size on the page is inconsistent with the browser size (compare the text circled in yellow in the image), especially for English, the former is larger and wider and the latter is smaller and narrower, which needs to be improved. :(
Re: v1.12.1 Inconsistent Font Size
you can change thumbnail label font in settings
alee001
Re: v1.12.1 Inconsistent Font Size [Solved]
Post by alee001 »
user0 wrote: Tue Oct 06, 2026 8:53 am you can change thumbnail label font in settings
Yes, it took me a long time to find the relevant settings. Thank you for the tip.
