1.12.1: 100% zoom affected by Zoom Out Anti-Aliasing setting
ddd
Post by ddd »
This bug occurs on both Windows and Linux with 150% display scaling (macOS probably unaffected since it only supports 100% and 200%) and "Scale on HiDPI screen" disabled. With 100% zoom and Zoom Out Anti-Aliasing set to anything other than None, there is a missing column of pixels in the attached image (right in the middle) - other than that single column XnViewMP seems to perfectly map image pixels to screen pixels as it should. With e.g. 100% or 200% scaling and/or Zoom Out Anti-Aliasing set to None, this does not occur.
Re: 1.12.1: 100% zoom affected by Zoom Out Anti-Aliasing setting
ddd
Post by ddd »
That is a bug report for a qt5-based version and seems like a combination (and a mess, honestly) of several different things/issues. I am pretty sure I have only started noticing this with the qt6-based beta builds.
Anyway, this report has a concrete settings combination that causes the (single) reported issue on the attached example image (both in Windows and Linux, so it should be universally reproducible - with the exception of macOS).
