Transfering personal settings to a new computer
Ilikemyprivacy
Post by Ilikemyprivacy »
I am transferring everything of mine from one computer to another. Xnview knows where my pictures are on my new computer but the ratings didn't transfer over. This is a list of everything I transferred over to my new computer...
1. My pictures (which is fine)
2. Everything in c:\Users\(myuserid)\Appdata\Roaming\XnViewMP which includes these files
autocorrect.txt
default.bar
default.keys
iptc.ini
search.ini
Thumb.db
Xmp.ini
XnView.db
xnview.ini
XnView-2026_04_30_10_38_28.db
What am I missing to get everything like my old computer? Is it because my username is different on my new computer and how do I fix that?
Re: Transfering personal settings to a new computer
your pictures are in the same path in new computer?
Ilikemyprivacy
They are in the same folder, on the same external hard drive, that is given the same drive letter D: on my new computer. The only thing different is my User name is something more private and less personal. If that is the reason how do I change it so xnview recognizes my picture ratings?
is it possible to send us the xnview.db?
xnview wrote: Mon Oct 12, 2026 6:21 am is it possible to send us the xnview.db?
you must be trolling that poor tinfoil-hat guy :P
bugreporter
Post by bugreporter »
Ilikemyprivacy wrote: Sun Oct 11, 2026 11:15 pm They are in the same folder, on the same external hard drive, that is given the same drive letter D: on my new computer. The only thing different is my User name is something more private and less personal. If that is the reason how do I change it so xnview recognizes my picture ratings?
So it is the identical, complete path to your picture folder(s) as before, or is the user name somewhere within the folder names? Check these paths in Tools, Settings (F12), Catalog, Maintenance. If it is the same, copying the XnView profile folder, as you did, should work...
BTW, google's AI has all the answers if you take a look, without having to wait for more or less useless answers. One recommended solution seems to be to embed your ratings directly in the pic's metadata and import them back into the new new/changed database.
Ilikemyprivacy
I think I see the problem, according to Tools, Settings, Catalog, Maintenance the directory is my old user name while my current user name is something less personal. How do I change it?
EDIT: Is there a way to manually upload the files I need? I really don't want to give anybody here my personal files if that's possible.
ANOTHER EDIT: I just remade another account with the same user name and it's still not working.
Ilikemyprivacy wrote: Mon Oct 12, 2026 6:12 pm ANOTHER EDIT: I just remade another account with the same user name and it's still not working.
So the path of your photos is the same now? and you have copied xnview.ini/xnview.db?
Ilikemyprivacy
xnview wrote: Tue Oct 13, 2026 6:15 am
The pictures always had the same path as they were/are on an external hard drive on both computers. I created a new user with the same user name as my last computer and it's still not working.
Is there a way to manually enter the .db file into the computer? Under settings/Catalog/Maintenance the Base path of files is just [ \ ]. I just go to my pictures using the side bar.
Can I make XnView portable so it only runs from the D: drive? I remember I did that once but got talked into installing it again and when I did even though I transferred all the database files back to the installed version I lost all the changes I made since switching from installed to portable.
Ilikemyprivacy
bugreporter wrote: Mon Oct 12, 2026 9:36 am
Google's AI leads me to posts where all the solution is simply to transfer the db file to the new computer. I tried that, it's not reading it.
Ilikemyprivacy
I figured out what the problem was. On my old computer my external hard drive isn't the D: Drive, it's called the F: Drive. So how do I fix that?
EDIT: I'm going to try and change my external drive from D:\ to F:\ I will let you know if it works.
Ilikemyprivacy
IT WORKED! EVERYTHING IS FINE NOW :D . Thank you everybody for your help, sorry to be a bother.
