The option to remove original file does not work, the original file are not delete.
I try to remove the config file to reconfigure , same effect file not remove.
Using option multi thread with replace if same name file.
Plateform Debian 13 + Kde Plasma 6.5 - wayland
Xnconvert install from DEB package.
Edit:
I make some investigation and the problem is link to the MergerFs file system, Xntool cant move file to trash on this filesystem...
Xnview as a similar problem with directory, (i select do not use trash but when i delete a folder it's a fail) :
#### trash: --- environment ---
#### trash: HOME=/home/ovn (dev=0x31)
#### trash: APPIMAGE=<unset>
#### trash: APPDIR=<unset>
#### trash: XDG_DATA_HOME=<unset>
#### trash: HOST_XDG_DATA_HOME=<unset>
#### trash: FLATPAK_ID=<unset>
#### trash: SNAP=<unset>
#### trash: passwd home=/home/ovn (dev=0x31)
#### trash: AppImage portable home=no
#### trash: data home=/home/ovn/.local/share (dev=0x31)
#### trash: --- deleting /home/ovn/Images/Works/_Tags/test (dev=0x2f)
#### trash: QFile::moveToTrash refused it, falling back to the XDG implementation
#### trash: source=/home/ovn/Images/Works/_Tags/test (dev=0x2f), data home=/home/ovn/.local/share probed as /home/ovn/.local/share (dev=0x31)
#### trash: other device than the data home: per-mount trash /home/ovn/Images/.Trash-1005
#### trash: rename to /home/ovn/Images/.Trash-1005/files/test failed errno=18
#### trash: gio: ok=0 exit=1 error=5
On other File system that seen to work...
Edit 2 :
So it s a Merger Fs problem in preserve folder structure mode, .Trash.UUID directory are not present on all drive.
Creating missing .Trash.UUID folder on all drive resolve my problem, Now remove file on xnconvert and xnview works.
XNConvert 1.118 Remove original not working [Problem Solve Mergerfs problem]
ovn76
