Could a new tool be made so as to move picture easily in Xnview MP ?
mailto.sales
I took a good picture, I wanted to check details in the picture, so I have to zoomed in the picture big enough. but it is very difficult to check each detail in Xnview MP because no suitable tool in XnView MP to move the picture so that it can be checked easily. then I suggest it can be make a new tool like symbol "hand", when using "hand" tool, can picture can be moved. This tool resembles tool in adobe acrobat.
KLE-France
Re: Could a new tool be made so as to move picture easily in Xnview MP ?
Your default 100% zoom keyboard shortcut is the asterisk key (use the one on the numeric keypad), then just left-click and pan.
Note too that at Tools > Settings > Interface > Mouse, you can assign Zoom & pan to Left button (or right or middle) > No modifier. This will give you the performance indicated by user0 without the need for the shift key. However, this one does not maintain the 100% zoom; it will return to the previous zoom level when you release the button. So, it's good to look at one thing quickly, but I more so suggest just using the 100% shortcut and then panning about (when the image is already at 100%, the left button just pans).
However, as far as I know, you cannot set keyboard shortcuts for other zoom percentages, which is a shame.
mailto.sales
Thank you telling me the shortcut for moving picture. It would be better if one moving tool is added.
jkm
A separate panning tool is unnecessary; that is not the way the application is designed to work.
You already have two excellent options for panning the image:
1. As has been mentioned, use Settings:Interface:Mouse. With this you can set a mouse button (modified with a key or not) to pan the image. Using the "Zoom and pan" setting to temporarily zoom the image when panning, and reset it afterwards. Using the "Pan image" option will pan the image without changing the zoom level. You can change these settings to fit your preferences.
2. Use the "Navigator". Enable this setting in Settings:Viewer:Zoom:Show navigator. When this feature is enabled, when you zoom into an image a small inset overlay will appear to allow you to drag the viewport anywhere in the image, in the style of Adobe applications.
Using the settings available to you in Settings:Interface:Mouse and your left, right, and middle mouse buttons with the scroll wheel, you can seamlessly select, pan, and zoom images without any need to switch tools to lock into a specific mode, and without needing to touch the keyboard. This is a more efficient approach, and is the way the application is intended to work.
jimking
The "Pan Image" option doesn't work.. Does't not zoom the image in order to viewing and navigate.jkm wrote: Wed Oct 14, 2026 10:25 pm 1. As has been mentioned, use Settings:Interface:Mouse. With this you can set a mouse button (modified with a key or not) to pan the image. Using the "Zoom and pan" setting to temporarily zoom the image when panning, and reset it afterwards. Using the "Pan image" option will pan the image without changing the zoom level. You can change these settings to fit your preferences.
The guy here means THIS:
viewtopic.php?p=217802#p217802
This is the meaning of panning.. during zoom! When the image fits on screen is pointless..
(try FastStone Image Viewer to understand what we mean..)
jkm
You mean that. That’s not what the OP said.jimking wrote: Thu Oct 15, 2026 12:27 pm The guy here means THIS:
If you want a “locked” zoom and pan, then either use the * key to zoom 1:1 as KLE said, or bind it to a mouse button. Or just zoom with the mouse wheel. Once zoomed (which is what the OP described) then “Pan image” pans the image.
jimking
I have use a lot of apps all these years and this thing was always simple and included by default. I don't want to use any keys only clicking..jkm wrote: Thu Oct 15, 2026 6:05 pm If you want a “locked” zoom and pan, then either use the * key to zoom 1:1 as KLE said, or bind it to a mouse button. Or just zoom with the mouse wheel. Once zoomed (which is what the OP described) then “Pan image” pans the image.
Where there is the option to "bind it to a mouse button".. I can't find it..
Could you please give me more details, because I'm new here and this thing makes crazy!
Some XnMP's menus are a bit confusing..
EDIT: After some research, I read this:
XnView MP does not have a native built-in menu to freely bind custom keyboard shortcuts directly to extra mouse buttons (like Mouse 4, Mouse 5, or custom side buttons).
However, you can configure basic mouse actions in the settings or use external software to map keyboard keys to your mouse.
1. Configure Built-in Mouse Settings
You can customize basic left, right, middle button, and wheel behavior directly inside XnView MP:
1. Open XnView MP.
2. Go to Tools > Settings (or press F12).
3. Navigate to Interface > Mouse (or Keyboard/Mouse).
4. Change the actions for the Left Button, Right Button, Middle Button, or Mouse Wheel from the available drop-down menus.
2. Map Keyboard Keys to Mouse Buttons via External Software
Because XnView MP lacks direct support for programming side buttons (Buttons 4 and 5) or custom key-to-mouse bindings, use a third-party mouse configuration tool:
• X-Mouse Button Control (XMBC): A free utility that lets you reassign specific mouse buttons to send simulated keystrokes (such as assigning Mouse 4/5 to trigger specific keyboard shortcuts used in XnView MP). You can download it from the X-Mouse Button Control Website.
• Mouse Manufacturer Software: If you use a Logitech, Razer, or Corsair mouse, open Logitech G HUB, Logitech Options, or equivalent software, create a profile specific to xnviewmp.exe, and assign desired keyboard keystrokes to your extra mouse buttons.
So there is no default option to do that, only by installing 3rd party app.? NO THANKS
jkm
It’s your choice as to what you do or don’t do, or whether you avail yourself of solutions presented to you. But you’ll have a better user experience overall if you can get past that attitude.jimking wrote: Thu Oct 15, 2026 6:53 pm So there is no default option to do that, only by installing 3rd party app.? NO THANKS
XnViewMP is itself “3rd party” software. So is the software that came with your mouse. So is Faststone. Faststone notably provides zero functionality for customizing keyboard shortcuts (like Irfanview) so Faststone users must resort to “3rd party” software like AutoHotKey to change key bindings.
You can learn to customize your mouse so you can adapt functionality in any application to work the way you want, or you can not do that, and resign yourself to complaining about how the software hasn’t adapted itself to your preferred approach and suffering through using apps that don’t work like you want.
Better to put a roof on your house than dread the rain.
You’ve been offered ways to address your problem, as the OP has been offered ways to address his. It’s up to you now. Good luck…
jimking
Look man.. I use PCs since 1988 with MS-DOS as my first experience. So I'm not a spoiled kiddo as you think and I know very well what I'm talking about. I have used and tested MANY apps all these years including photo viewers managers and editors! My suggerstion - request is actually a VERY common observation of MANY XnView users. It's not just me. Make a research first and you'll see that a lot of people are frustrated from that missing zoom option.. If you don't want to accept it.. it's up to you..jkm wrote: Thu Oct 15, 2026 8:12 pmIt’s your choice as to what you do or don’t do, or whether you avail yourself of solutions presented to you. But you’ll have a better user experience overall if you can get past that attitude.jimking wrote: Thu Oct 15, 2026 6:53 pm So there is no default option to do that, only by installing 3rd party app.? NO THANKS
The rule says that we generally use third-party apps in order to find better experience and more available options. I never said that XnView MP is crap or a bad program. I actually think the opposite, that's why I decided to open a topic in the SUGGESTIONS section because this section exists for this reason. Or not? To report IMPORTANT things that will help developers improve their app. With all respect I actually wait an official reply from them, not from a "fan" member who apparently likes to mini-mod, replies to the users and wants to show everything good and functional. There is always room for improvement! Installing extra stuff for as a such simple ONE option that ALL other viewers/managers have by default for me is not the right way to do it. It's silly. And as I read some older replies in blogs, this option existed in the past but it has been removed. So instead of finding excuses for the Devs and half-measures, plus blame users themselves that we complain without a reason, I friendly suggest you to keep your position as member, because you only cause damage to them with your attitude and replies. Thank you for your wish for good luck, but it's just a pc program after all and surely that missing option will not ruin my day. There are more important things in life that require "good luck"..
For me the topic is closed here and I really hope the developers listen to all users and add that option back in!
Bye!
