Adjustable menu font size
Sergei
Post by Sergei »
I'm using AppImage of XnView MP 1.12.2 on Linux (Manjaro XFCE) with the Light theme.
The font in the main menu bar (File, Edit, View, etc.) is too small. I would like to increase the font size of the main menu bar without changing the font sizes of other UI elements or the overall application scaling.
I've attached a screenshot to illustrate the issue.
Is there currently a way to adjust the main menu bar font size while keeping the Light theme?
If not, could you please consider adding a separate setting for the menu bar font size?
Ideally, this setting would allow users to adjust the font size independently of the rest of the interface, regardless of the selected theme.
Thank you for your work on XnView MP!
