I am working with NConvert (unicode) version 7.240 and 7.301 on Win10.
My questions is:
- does Nconvert support long pathnames ( > MAX_PATH)?
- how must I send the (long) filename to NConvert
My tested commands is
Nconvert ...some options... "<filename with long pathname>"
Nconvert ...some options... "\\?\<filename with long pathname>"but using long pathnames for both I get: "Cannot open file"
Would it be possible that NConvert also supports long pathnames?
Thanks in advance
Best regards
herb
