Extended version of the Custom stylesheet
HanVroon
Post by HanVroon »
The beginning of 2025 I started to investigate the stylesheet that comes with XnViewMP calls Custom, formerly Old Dark.
Because the existing dark themes that can be selected through Settings were not my taste, I started defining my own 30 shades of grey version.
This soon devolved into a hobby project. The original stylesheet was rather basic, selectors and properties were missing (like for bottom tabs), some screen elements where still coloured.
Because I documented everything that I found out, including very specific things like addressing the Actions tab in Batch convert, all these comments started to get quite valuable.
So only for those who use the Custom stylesheet option:
Though the colours might not be your taste, all the comments might help you to identify a missing setting in your own Custom stylesheet version.
This stylesheet is based on C:\Program Files\XnViewMP\UI\style_sheet.qss.
  • Modified between February 2025 and Oktober 2026, last changes for the sake of Qt6.
  • It has been expanded with missing Selectors, some Properties of existing Selectors were added.
  • The ordering of Selectors is exactly the same as the original provided by XnViewMP to make comparing what changed easy.
  • Every addition was a result of experimenting without access to the source code of XnViewMP.
  • Almost every Selector or group of Selector has been documented.
  • Some Selectors without Properties are left there as a reference.
  • Only two colours are set by name: black and white.
  • All other colours are in rgb(n, n, n) format, always with a space after the comma, so you can easily search/replace a specific colour throughout the stylesheet.
For those who want to play with this custom stylesheet but don't know how to do that:
  • It starts with opening Settings, General, Theme: select Custom.
  • This will copy \XnViewMP\UI\style_sheet.qss to your profile folder. The file will also show up in a windows, you can close that.
  • Where this file is put depends on your settings:
    If you never changed Settings, Integration, Paths and then the paths for Configuration and Settings-Other:
    Windows: The file will be in C:\Users\<your logon name>\AppData\Roaming\XnViewMP.
    Linux: (most likely, not sure) in /home/<you>/.config/xnviewmp.
  • If you did change the paths, you know where to find the file.
  • If you never used the Custom theme, you can delete the contents of the file and replace it with the text below, because the original will still be in \XnViewMP\UI\style_sheet.qss.
  • After this you can modify this file the way you like. Close and open XnViewMP to see the changes.
I am not a Qt programmer nor stylesheet expert. Most was accomplished with googeling and a lot of trial on error (what changes after changing color or background-color to (solid) red?), being an IT guy helped.
After the upgrade to Qt6 the meanwhile grown up Gemini helped me. So much can change in a year!
The only thing I haven't been able to fix is the hardly readable dark blue URLs on the About pages, the colour is still inherited from Windows (on a Windows system).
Having all the comments in Dutch have held me back for a long time to put this stylesheet here, until the ligjt went on and I realized Gemini can do that too! I checked all the translations and they are OK.
So here it is, happy tweaking!
PS: due to policy limitations I cannot upload a .qss or .txt, so I hope it works in a code block.
- Modified between Febuary 2025 and Oktober 2026, last changes for the sake of Qt6.
- It has been expanded with missing Selectors, some Properties of existing Selectors were added.
- The ordering of Selectors is exactly the same as the original provided by XnViewMP to make
- Every addition was a result of experimenting without access to the source code of XnViewMP.
- Almost every Selector or group of Selector has been documented.
- Some Selectors without Properties are left there as a reference.
- Only two colors are set by name: black and white.
- All other colors are in rgb(n, n, n) format, always with a space after the comma, so you can easily
  search/replace a specific color throughout the stylesheet.
/* Everything that is not assigned another color, such as Browser toolbar above thumbnails,
   tabbars, space between panels. Tabbars can get a different color independent of this setting. */
QMainWindow{
    background-color: rgb(60, 60, 60);
    /* border: 1px solid red; */
/* Only the buttons of the Browser toolbar and all buttons in the panels, for Qt6. */
QMainWindow QToolButton{
    margin: 1px;
/* Width between all panels */
QMainWindow::separator {
    /* width: 10px; */
/* Space between the two panels where the mouse is */
QMainWindow::separator:hover {
    /* background-color: rgb(200, 200, 200); */
/* Buttons like OK in Dialogs, all buttons in Settings. Padding was 1ex 2ex, adjusted for Qt6. */
QPushButton{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(90, 90, 90), stop:1 rgb(60, 60, 60));
    border: 1px solid black;
    color:rgb(250, 250, 250);
    padding: 2px 4px;
/* Buttons mouse over */
QPushButton::hover{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(150, 150, 150), stop:1 rgb(120, 120, 120));
    color:rgb(255, 255, 255);
/* Buttons pressed */
QPushButton:pressed{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(120, 120, 120), stop:1 rgb(90, 90, 90));
/* Positioning text inside the buttons */
QDialogButtonBox > QPushButton, QDialog > QPushButton, QWizard > QWidget > QPushButton{
    min-width: 5em;
    min-height: 1.4em;
/* Title text color of the panels */
QDockWidget{
/* Titles of the panels.
   Padding used to be padding: 0.4em, lower part character g invisible, now correct. */
QDockWidget::title{
   background-color: rgb(90, 90, 90);
   padding-top: 2px;
/* Category Sets panel body and border, the bar under Catalog filter, and the Map tab of Info panel.
   For other panels see QTreeView. By setting the border to 1 here and in the next setting
   (QDockWidget QScrollArea) the border to 0, the bar under Catalog filter is neatly outlined. By
   setting the top border to 0, the Map tab in Info panel no longer has a border at the top. Only
   the top border in Category Sets is now missing, but it was barely visible anyway, and in Categories
   it has been missing for a long time.
   See ActionPanelHeader at the bottom of this stylesheet for the light gray bars. */
QDockWidget .QWidget{
    border: solid black;
    border-width: 0px 1px 1px 1px;
/* Category Sets panel, inside around the boxes, border to 0, otherwise double line due to
   QDockWidget .QWidget above. */
QDockWidget QScrollArea{
    border: 0px solid black;
/* The close and undock buttons in the bars of the panels.*/
QDockWidget::close-button:hover, QDockWidget::float-button:hover {
    border: 1px solid rgb(180, 180, 180);
    border-radius: 3px;
/* HeaderView are the column headers in the thumbnail panel at View as Details, and e.g. in the Settings
   screens Auto correct, Shortcuts, File list, Columns and Custom filter.
   Set the border-top set to 0 due to double black line above the column headers. Consequently, no
   longer a border above Browser in Details view, but that is less noticeable. */
QHeaderView::section{
   color: rgb(250, 250, 250);
/* Column headers */
   padding: 1ex;
/* Left column header */
QHeaderView::section:first{
   border-top: 0px solid black;
   border-right: 0px solid black;
   border-bottom: 1px solid black;
   border-left: 0px solid black;
/* All column headers except the outer ones */
QHeaderView::section:middle{
   border-left: 1px solid black;
/* Right column header */
QHeaderView::section:last{
/* Mouse over a column header */
QHeaderView::section:hover{
/* Pressing column header */
QHeaderView::section:pressed{
     background-color:  qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(120, 120, 120));
/* Sort arrow down */
QHeaderView::down-arrow {
    image: url("UI:arrow_down_V2.png");
    width: 10px;
    height: 10px;
    padding-right: 1ex;
/* Sort arrow up */
QHeaderView::up-arrow {
    image: url("UI:arrow_up_V2.png");
    width: 10px;
    height: 10px;
    padding-right: 1ex;
Scrollbar colors:
  Scrollbar = 70
  Handle and arrows = 120
  Handle and arrows mouse over = 160
  Handle and arrows pressed = 200
QScrollBar{
    background-color: rgb(70, 70, 70);
/* No color in the empty part of the scrollbar outside the handle */
QScrollBar::add-page, QScrollBar::sub-page {
    background: none;
/* No border left and right of horizontal scrollbar, scrollbar indented 14 px.
   Added height for Qt6. */
QScrollBar::horizontal{
    border: 1px solid rgb(90, 90, 90);
    border-left: 0px;
    border-right: 0px;
    margin: 0px 14px 0px 14px;
    height: 2.8ex; /* NEW IN QT6: Stable baseline height for High-DPI */
/* No border top and bottom of vertical scrollbar, scrollbar indented 14 px.
   Added width for Qt6. */
QScrollBar::vertical {
    border-top: 0px;
    border-bottom: 0px;
    margin: 14px 0px 14px 0px;
    width: 2.8ex;  /* NEW IN QT6: Stable baseline width for High-DPI */
/* Handle = the slider of scrollbars */
QScrollBar::handle{
    background-color: rgb(120, 120, 120);
    border-radius: 1px; /* rounded corners does not work when so narrow */
/* Standard narrow handle, horizontal. From 6px to 1ex for Qt6. */
QScrollBar::handle:horizontal{
    margin-top: 1ex;     /* due to space outside the handle, the handle becomes narrower */
    margin-bottom: 1ex;  /* due to space outside the handle, the handle becomes narrower */
    min-width: 20px;     /* prevent handle from becoming a point at high zoom levels */
/* Standard narrow handle, vertical. From 6px to 1ex for Qt6. */
QScrollBar::handle:vertical{
    margin-left: 1ex;    /* due to space outside the handle, the handle becomes narrower */
    margin-right: 1ex;   /* due to space outside the handle, the handle becomes narrower */
    min-height: 20px;    /* prevent handle from becoming a point at high zoom levels */
/* Color of the handle mouse over */
QScrollBar::handle:hover {
    background-color: rgb(160, 160, 160);
    border-radius: 2px; /* rounded corners */
/* Make handle thicker on mouse over, horizontal. Adjusted for Qt6. */
QScrollBar::handle:horizontal:hover {
    background-color: rgb(160, 160, 160); /* Explicitly repeat color here for Qt6 */
    margin-top: 0.8ex;     /* due to space outside the handle, the handle becomes narrower */
    margin-bottom: 0.8ex;  /* due to space outside the handle, the handle becomes narrower */
/* Make handle thicker on mouse over, vertical. Adjusted for Qt6. */
QScrollBar::handle:vertical:hover {
    margin-left: 0.8ex;    /* due to space outside the handle, the handle becomes narrower */
    margin-right: 0.8ex;   /* due to space outside the handle, the handle becomes narrower */
/* Color of the handle pressed, per orientation for Qt6. */
QScrollBar::handle:horizontal:pressed {
    margin-top: 0.8ex;
QScrollBar::handle:vertical:pressed {
    margin-left: 0.8ex;
/* Add-line and sub-line are the squares left/right or top/bottom of the scrollbar, not the
   arrows themselves.
   By default make all scrollbar arrows invisible using background color.
   Do not set border (not even to none), managed in individual settings per arrow.
   Subcontrol settings per bar (horizontal or vertical) and further per arrow direction. */
/* Horizontal general. */
QScrollBar::add-line:horizontal, QScrollBar::sub-line:horizontal {
    background: rgb(70, 70, 70);
    subcontrol-origin: margin;
    width: 14px;
/* Horizontal arrow to the right. */
QScrollBar::add-line:horizontal {
    subcontrol-position: right;
    border-left: 0px;
/* Horizontal arrow to the left. */
    subcontrol-position: left;
    border-right: 0px;
/* Vertical general. */
QScrollBar::add-line:vertical, QScrollBar::sub-line:vertical {
    height: 14px;
/* Vertical arrow down. */
QScrollBar::add-line:vertical {
    subcontrol-position: bottom;
    border-top: 0px;
/* Vertical arrow up. */
    subcontrol-position: top;
    border-bottom: 0px;
/* Creating arrows. It starts with creating a square with a thick border in background color.
   Then one side of the border is changed to the arrow color, creating a triangle.
   Always three color settings: normal, hover, and pressed.
   From: https://stackoverflow.com/questions/77769147/how-to-customize-a-qscrollbar */
QScrollBar::left-arrow:horizontal, QScrollBar::right-arrow:horizontal, QScrollBar::up-arrow:vertical, QScrollBar::down-arrow:vertical {
    border: 5px solid rgb(70, 70, 70);
    width: 0px;
    height: 0px;
/* Left arrow horizontal */
QScrollBar::left-arrow:horizontal{
    left: -2px;
    border-right-color: rgb(120, 120, 120);
QScrollBar::left-arrow:horizontal:hover{
    left: -2px;
    border-right-color: rgb(160, 160, 160);
QScrollBar::left-arrow:horizontal:pressed{
    left: -2px;
    border-right-color: rgb(200, 200, 200);
/* Right arrow horizontal */
QScrollBar::right-arrow:horizontal{
    right: -2px;
    border-left-color: rgb(120, 120, 120);
QScrollBar::right-arrow:horizontal:hover{
    right: -2px;
    border-left-color: rgb(160, 160, 160);
QScrollBar::right-arrow:horizontal:pressed{
    right: -2px;
    border-left-color: rgb(200, 200, 200);
/* Top arrow vertical */
QScrollBar::up-arrow:vertical {
    top: -2px;
    border-bottom-color: rgb(120, 120, 120);
QScrollBar::up-arrow:vertical:hover {
    top: -2px;
    border-bottom-color: rgb(160, 160, 160);
QScrollBar::up-arrow:vertical:pressed {
    top: -2px;
    border-bottom-color: rgb(200, 200, 200);
/* Bottom arrow vertical */
    bottom: -2px;
    border-top-color: rgb(120, 120, 120);
QScrollBar::down-arrow:vertical:hover {
    bottom: -2px;
    border-top-color: rgb(160, 160, 160);
QScrollBar::down-arrow:vertical:pressed {
    bottom: -2px;
    border-top-color: rgb(200, 200, 200);
/* Body of panels Folders, Info, Catalog filter, Categories, not of Category Sets, and of
   thumbnail details, and a number of Settings screens such as Formats.
   Background and alternate-background: zebra striping colors per line in info panel body. Alternate has
   the same color as the environment, non-alternate is lighter.
   A number of settings do not work on thumbnail details, such as item and indicator. */
QTreeView{
    alternate-background-color: rgb(100, 100, 100);
/* No more double line between Folders panel title and body, under the tabs of the Info panel, and
   at the top of the Catalog filter. Missing top border in Settings screens also resolved with the
   following setting. */
    border-top: 0px;
/* For Qt6, no white border around focused item. When placed here, it works not only for Favorites
   and Folders, but also for the Categories panel. */
    outline: 0;
/* Due to the settings above, all treeviews in the Settings screen had no border at the
   top. So explicitly turn it back on. Without adding a color nothing happens. */
QDialog QTreeView{
    border-top: 1px solid black;
/* Nothing visible when changing to red.
   But if text color red is added, a Rating and Colour label in the Info panel are red.*/
QTreeView:active{
    selection-background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(80, 80, 80), stop:1 rgb(60, 60, 60));
/* Nothing visible when changing to red */
QTreeView:!active{
    selection-background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(80, 80, 80), stop:1 rgb(70, 70, 70));
/* Text of the lines of panels Folders, Info, Catalog filter, Categories, not of Category Sets.
   Optional space between lines. Item text has a color, alternate does not, so same color. */
QTreeView::item{
    border: 0px solid red;
QTreeView::item:alternate{
    /* color: red; */
/* Selected line of a panel without focus (not clicked in) */
QTreeView::item:selected:!active{
/* Selected line of a panel with focus (clicked in). For Qt6, the white border around the
   item had to be removed first (see outline at QTreeView) and then redefined
   as a dotted line below. Removed the dotted border, didn't look good. */
QTreeView::item:selected:active{
    /* border: 1px dotted rgb(230, 230, 230); */
/* Line in any panel where the mouse hovers. */
QTreeView::item:hover{
/* Arrows in the Folder, Catalog filter and Categories panels, fixed color, cannot be modified */
/* Disabled, the default arrows are a bit more discreet. */
/*QTreeView::branch:closed:has-children:!has-siblings, QTreeView::branch:closed:has-children:has-siblings{
    image: url(UI:treeview_arrow_right.png);
/*QTreeView::branch:open:has-children:!has-siblings, QTreeView::branch:open:has-children:has-siblings{
    image: url(UI:treeview_arrow_down.png);
/* Indicators here are the checkbox columns in e.g. the Categories panel, or Settings, Formats.
   There are separate images for check/uncheck and enabled/disabled. */
QTreeView::indicator{
    width: 14px;
    height: 16px;
QTreeView::indicator:unchecked{
     image: url(UI:checkbox_unchecked.png);
QTreeView::indicator:unchecked:disabled{
     image: url(UI:checkbox_unchecked_disabled.png);
QTreeView::indicator:checked{
     image: url(UI:checkbox_checked.png);
QTreeView::indicator:checked:disabled{
     image: url(UI:checkbox_checked_disabled.png);
QTreeView::indicator:indeterminate{
     image: url(UI:checkbox_indeterminate.png);
QTreeView::indicator:indeterminate:disabled{
     image: url(UI:checkbox_indeterminate_disabled.png);
/* Background of the topics column on the left in Settings, and of e.g. Settings, Thumbnail, Labels.
   No longer of the views without details of the Browser, see MyThumbListView at the bottom of the stylesheet. */
QListView{
    background-color: rgb(140, 140, 140);
/* Text color, padding because the list on the left in Settings became more spaced out in Qt6 */
QListView::item{
    color: rgb(20, 20, 20);
    padding: -1px;
/* Alternate text color (every other line) does nothing */
QListView::item:alternate{
/* Text color selected line */
QListView::item:selected{
/* Background selected line when no focus */
QListView::item:selected:!active{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(60, 60, 60), stop:1 rgb(60, 60, 60));
/* Background selected line when focused */
QListView::item:selected:active{
/* Line where the mouse hovers.
   Text color added here as well, otherwise it becomes very dark on dark */
QListView::item:hover{
/* Table as used in Settings, File list, Custom filter or Companion files.
   Originally only the first selector (QTableView) was here, the rest is fully customized, looking for checkbox
   settings that were all default Windows colors. Everything copied from QTreeView. */
QTableView{
/* Selected cell in the table. */
QTableView::item:selected{
    color: white;
QTableView:active{
QTableView:!active{
/* Text of the lines of the panels Folders, Info, Catalog filter, not of Category. Optional space
   Border only works on Settings, File list, Companion files and Custom filter. */
QTableView::item{
    /* border: 1px solid green; */
QTableView::item:alternate{
    /* color: red; */
/* Setting for :disabled at top of stylesheet might be overwritten by item setting above. */
QTableView::item:disabled{
    color: rgb(130, 130, 130);
QTableView::item:selected:!active{
/* Selected line of a panel with focus (clicked in) */
QTableView::item:selected:active{
QTableView::item:hover{
/* Indicators are checkboxes. There are separate images for check/uncheck and enabled/disabled. */
QTableView::indicator{
    width: 14px;
    height: 16px;
QTableView::indicator:unchecked{
QTableView::indicator:unchecked:disabled{
QTableView::indicator:checked{
QTableView::indicator:checked:disabled{
/* Color of the menu bar, blends into the gradient of the toolbar (90 to 60) */
QMenuBar{
    border-right: 1px solid black;
/* Color of the menu items, no background, padding (space around menu text) added for Qt6 */
QMenuBar::item{
    background-color: transparent;
    padding: .7ex 1ex;
/* Color of the menu item where the mouse hovers */
QMenuBar::item:selected{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(130, 130, 130));
/* Submenu, background and text color. Padding handles space around the menu itself. */
QMenu{
    padding: 5px;
/* Lines of the submenu, space left and right of the text */
QMenu::item{
    border: 1px solid transparent;
    padding: 2px 25px 2px 20px;
/* Submenu item where the mouse hovers */
QMenu::item:selected{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(150, 150, 150), stop:1 rgb(100, 100, 100));
/* Lines between groups of submenu items */
QMenu::separator{
   height: 1px;
   background-color: rgb(250, 250, 250);
   margin: 5px 25px 5px 20px;
/* Background of all dialog windows (Settings, Levels, etc). No border looks better. */
QDialog{
/* The body of the Actions tab of Batch convert, and the Extensions area of Video in the table of
   Settings, File list, Custom filter, and the body background of menu Create, File listing.
   Originally only border was here, background added. Adding color for text does nothing.
   See also ActionPanel, ConvertActionPanel and CategorySetPanel at the bottom, without this setting
   they do not work properly. */
QDialog QWidget#qt_scrollarea_viewport > QWidget {
/* shape=0 are the tabs at the top (opened files)
   shape=1 are tabs at the bottom (for panels on top of each other). */
/* Adjustment for Qt6, slightly smaller font, normally a font must be supplied, the value normal
   keeps the line valid without needing to specify a font. */
QTabBar {
    font: normal 8pt;
/* Colors of all tabs */
/* Padding: space around the text of the tabs, was 1ex 3ex, adjusted for Qt6 */
QTabBar::tab{
    border: 1px solid;
    border-color: rgb(55, 55, 55);
    min-width: 2em;
    padding: .4ex 1.1ex;
/* Active tab at the top, different color, rounded corners, line below it in different color */
QTabBar[shape="0"]::tab:selected{
    border-top-left-radius: 4px;
    border-top-right-radius: 4px;
/* Active tab at the bottom, different color, rounded corners, line above it in different color */
QTabBar[shape="1"]::tab:selected{
    border-bottom-left-radius: 4px;
    border-bottom-right-radius: 4px;
/* After long experimentation, active tab at the bottom seemed to be behind another tab on the right side,
   other tabs had a double line at the top. Only affected tabs at the bottom. */
QTabBar[shape="1"]::tab{
    border-top: 0px;
/* No double line between two tabs, middle tabs */
QTabBar::tab:middle{
    border-left: 1px;
/* No double line between two tabs, last tab */
QTabBar::tab:last{
    border-left: 1px;
/* Active tab at the top is 2 pixels higher, other tabs become 2 pixels lower (! = not) */
QTabBar[shape="0"]::tab:!selected{
    margin-top: 2px;
/* Active tab at the bottom is 2 pixels lower, other tabs become 2 pixels lower (! = not) */
QTabBar[shape="1"]::tab:!selected{
    margin-bottom: 2px;
/* Tab where the mouse hovers becomes darker, except for the active tab (! = not) */
QTabBar::tab:!selected:hover{
/* Frame around the info panel and e.g. Settings, Formats, Read */
QTabWidget::pane{
    border: 1px;
/* Active tab of the tabbar of the Info panel. Only goes wrong on the histogram tab. */
QTabWidget > QTabBar[shape="0"]::tab:selected{
    border-bottom-color: rgb(90, 90, 90);
/* The other tabs of the tabbar of the Info panel. Only goes wrong on the histogram tab. */
QTabWidget > QTabBar[shape="0"]::tab:!selected{
    border-bottom-color: rgb(55, 55, 55);
/* Tab of the tabbar of the Info panel where the mouse hovers becomes darker, except for the active
   tab (! = not) */
QTabWidget > QTabBar::tab:!selected:hover{
/* Settings, and then screens containing tabs, such as Formats, Read. Color a bit lighter, and border.
   Border-top to 0, otherwise creates a line under the active tab, unlike with the Info panel. */
DlgSettings QTabWidget::pane {
    /* No line under the tabs. */
    border-top: 0px;
/* The tabs in the Batch convert window. Needed extra specification. Color a bit lighter, and border.
   This does result in a missing top border in Category sets settings (3 dots button). */
QDialog QTabWidget::pane {
    border-top: 0px;
/* Two DlgSettings QTabBar settings removed, were redundant, inherited from above.
   See version 7 for what used to be here. */
/* Long searched for, gray line next to the tabs of panels (Favorites/Folders and Category).
   See: https://stackoverflow.com/questions/28551058/qtabbar-strange-line-doesnt-disappear
   Can reappear when moving panels or Restoring Layout C, but after restart the line
   is gone again. Seems no longer applicable in Qt6. */
QTabBar{
    qproperty-drawBase: 0;
/* Progress bar, e.g. when caching thumbnails of many photos. Made lighter. */
QProgressBar{
    background-color:  qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(200, 200, 200), stop:1 rgb(150, 150, 150));
    text-align: center;
/* Percentage complete bar in the progress bar. Borders to make the bar narrower. Margins to
   get the bar left and right also 3px within the progress bar. For Qt6, replaced top/bottom border
   with all-around margin. */
QProgressBar::chunk{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(150, 150, 150), stop:1 rgb(110, 110, 110));
    border: none;
    margin: 3px;
/* Removes all vertical lines between values on the status bar. Done due to the vertical
   line that was to the right of the progress bar, which looked strange. */
QStatusBar::item {
    border: none;
/* Since there are no more vertical lines between the values, increased the space between them a bit. */
QStatusBar QLabel{
    padding: 0px 3px;
/* Large toolbar at the top. The Browser toolbar is never changed, even if this setting is at the bottom
   of the stylesheet. Padding from 5 to 1 for Qt6. */
QToolBar{
    /* border: 5px solid red; */
    border: 0px;
    padding: 1px;
/* Only the buttons of the large toolbar slightly further apart, for Qt6. Had resolved this earlier
   at QToolButton, but then buttons at the top of panels are too high. */
QToolBar QToolButton{
    margin: 1px;
/* Large toolbar at the top. Flows from the gradient of the menu bar (120 to 90). */
QToolBar:horizontal{
/* Vertical toolbar (dragging the handle on the left of the toolbar), nothing done with it yet. */
QToolBar:vertical{
    background-color: qlineargradient(x1:0, y1:0, x2:1, y2:0, stop:0 rgb(90, 90, 90), stop:1 rgb(60, 60, 60));
/* Separation lines between icon groups on the toolbar */
QToolBar:separator{
   background-color:qlineargradient(x1:0, y1:0, x2:1, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(90, 90, 90));;
   width:1px;
   height:1px;
   margin:5px;
/* Messed around with due to 1 column of dots instead of 2, left for reference */
QToolBar::handle{
/* Slider bar of e.g. thumbnail size and Enhance colors */
QSlider::groove:horizontal {
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(140, 140, 140));
    border: 1px solid rgb(60, 60, 60);
    height: 4px; /* make the groove narrower than the slider area */
/* The handle */
QSlider::handle:horizontal {
    width: 8px;
    margin: -2px 0; /* make the handle wider than the slider bar, better visibility */
    border-radius: 2px;
/* The handle, mouse over */
QSlider::handle:horizontal:hover {
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(250, 250, 250), stop:1 rgb(180, 180, 180));
/* Status bar */
QStatusBar{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(60, 60, 60), stop:1 rgb(90, 90, 90));
/* Special buttons in Settings, such as three dots or an arrow, also the move buttons in e.g.
   Interface, Toolbar or Browser, Columns. (DlgSettings is the entire window of Settings) */
DlgSettings QToolButton {
    /* padding: 1ex 2ex; */
/* All buttons of all toolbars and panels, with and without text. Nothing in Settings. For Qt6
   margin 1px removed, for the large toolbar this is now managed in QToolBar QToolButton.
   Margin is ignored here by QToolBar QToolButton for the large toolbar and QMainWindow QToolButton
   for the Browser toolbar and all buttons in panels. Padding would still work here. */
QToolButton{
    border-radius: 3px;
/* With mouse over. */
QToolButton::hover{
/* Background of toolbar button that remains pressed, such as Show information at View mode. */
QToolButton::checked{
    background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(150, 150, 150));
/* Background of toolbar button at the moment it is pressed. */
QToolButton::pressed{
/* Background of buttons with an arrow containing options, such as Layout.
   Without padding, the arrow stands in the text. */
QToolButton[popupMode="1"]{
    padding-right: 10px;
/* The arrow of buttons with an arrow, like Layout, no settings without mouse over.
   Added the background color for the arrow at the top in Categories which was dark blue.
   Added width for Qt6, arrow became too wide. */
QToolButton::menu-button{
    width: 10px;
/* The arrow of buttons with an arrow, with mouse over. Same as QToolButton::hover, must
   get its own border, as it overlays the rest of the button. */
QToolButton::menu-button:hover{
    border-top-right-radius: 3px;
    border-bottom-right-radius: 3px;
/* The arrow of buttons with an arrow, pressed. */
QToolButton::menu-button:pressed{
    background-color: rgb(80, 80, 80);
/* Text color of quite a few screens in Settings and Dialogs, except groupbox titles.
   Probably like text labels in forms in Delphi. */
QLabel, QCheckBox, QRadioButton{
/* The boxes where values are changed with up/down arrows, such as in Levels. Colors slightly
   adjusted. Padding for Qt6. */
QSpinBox, QDoubleSpinBox {
   padding:0px;
   selection-background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(180, 180, 180), stop:1 rgb(150, 150, 150));
   selection-color: rgb(255, 255, 255);
    padding-left: -3px;
/* Separate spinbox buttons, do not seem to be used. */
QSpinBox::up-button, QSpinBox::down-button, QDoubleSpinBox::up-button, QDoubleSpinBox::down-button {
     subcontrol-origin: border;
     width: 16px;
     border-width: 0px;
QSpinBox::up-button, QDoubleSpinBox::up-button {
     subcontrol-position: top right;
QSpinBox::down-button, QDoubleSpinBox::down-button {
     subcontrol-position: bottom right;
/* Spinbox arrows inside the box, up/down, are used. */
QSpinBox::up-arrow, QDoubleSpinBox::up-arrow {
     border-image: url(UI:spinbox_up.png);
     height:7px;
QSpinBox::down-arrow, QDoubleSpinBox::down-arrow {
     border-image: url(UI:spinbox_down.png);
     height:7px;
/* Checkboxes in almost all dialogs.
   For checkboxes in lists see QTreeView::indicator.
   For checkboxes in tables see QTableView::indicator.
   For checkboxes above groupboxes see QGroupBox::indicator.
   The tag checkboxes in the treeview of thumbnail details cannot be modified. */
QCheckBox::indicator:unchecked{
QCheckBox::indicator:unchecked:disabled{
QCheckBox::indicator:checked{
QCheckBox::indicator:checked:disabled{
/* The radio buttons. See for example Settings, General, Startup. */
QRadioButton::indicator:unchecked{
     image: url(UI:radiobutton_unchecked.png);
QRadioButton::indicator:unchecked:disabled{
     image: url(UI:radiobutton_unchecked_disabled.png);
QRadioButton::indicator:checked{
     image: url(UI:radiobutton_checked.png);
QRadioButton::indicator:checked:disabled{
     image: url(UI:radiobutton_checked_disabled.png);
/* Text fields such as the field at the top of the Categories and Category Sets panel, Quick search field in the
   Browser toolbar.
   The text color (color) also works on the combobox path in the Browser toolbar, nowhere else. */
QLineEdit{
    padding: 0px;
    color: black;
    selection-background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(120, 120, 120), stop:1 rgb(90, 90, 90));
    selection-color: black;
    margin: 1px 0px 0px 3px;
/* All Comboboxes such as the path in the Browser toolbar and Batch convert, and all in Settings. */
QComboBox{
     padding: 0px 18px 0px 3px;
/* Comboboxen that cannot be modified (most of them). */
QComboBox:!editable, QComboBox::drop-down:editable{
/* Comboboxes that can be edited, like the path in the Browser toolbar (path is editable).
   Selection-color changed from 80 to black, was almost unreadable. */
QComboBox:editable{
    selection-background-color: qlineargradient(x1:0, y1:0, x2:0, y2:1, stop:0 rgb(150, 150, 150), stop:1 rgb(120, 120, 120));
/* For editable this concerns the color of the arrow, for not editable the whole field. */
QComboBox:!editable:on, QComboBox::drop-down:editable:on{
/* The arrow in the combobox. */
QComboBox::drop-down{
     subcontrol-origin: padding;
     width: 15px;
     border: 0px;
/* The arrow in the combobox, mouse over. */
QComboBox::drop-down:hover{
/* The image for the arrow in the combobox. */
QComboBox::down-arrow{
     image: url(UI:dropdown_arrow.png);
/* Item with the mouse over when combobox is opened, outline ensures no dotted line box around the
   selected item. Everything newly added (see also the default style_sheet_win.qss file in UI). */
QComboBox QAbstractItemView {
    outline: 0px;
    selection-background-color: rgb(150, 150, 150);
/* All boxes in dialogs that frame groups of settings. */
QGroupBox{
/* Title above the groupbox, used to be 1.1 em, text was tight against the border, now higher. */
    margin-top: 1.3em;
    font-weight: bold;
/* The titles above a groupbox. Strange, at 1px some title tops do not turn red (Settings, Catalog). */
QGroupBox::title{
    top: 0px;
/* The checkboxes in titles of groupboxes, such as Settings, General, Color profile and Settings, Catalog
   Completely added, using QTableView as example. Height and width were also required. */
QGroupBox::indicator{
    /* background-color: red; */
    width: 14px;
    height: 16px;
QGroupBox::indicator:unchecked{
QGroupBox::indicator:unchecked:disabled{
QGroupBox::indicator:checked{
QGroupBox::indicator:checked:disabled{
/* Two free text fields in Settings: Browser, Tooltip or View, Info. */
QTextEdit{
    selection-background-color:  rgb(60, 60, 60) ;
    selection-color: rgb(250, 250, 250);
/* Tooltip when mouse hovers over a file in the Browser. Background does not work, color: red does. */
QToolTip{
/* Various separate elements and screens or panels. */
/* Everything that is disabled such as menu options that are not applicable
   Testing: see Settings, File list, Custom filters, top line (Images).
   And: menu Metadata, Face tag (disabled menu option). */
:disabled{
QWizard{
/* Nothing visible with background red. */
QWizard .QWidget{
      background-color: rgb(40, 40, 40);
QWizard .QFrame{
QWizard  > .QWidget > .QLabel{
QWizard QListView{
QWizardPage .QFrame{
/* The Quick filter (search) field in the Browser toolbar. Margin adjusted for Qt6, right 13px ensures
   the field lines up with the three dots button. */
SearchLineEdit{
    /* top right bottom left */
    margin: 1px 13px 4px 3px;
    /* margin: 1px 3px 4px 3px; magnifying glass correct*/
    color: white;
/* The buttons in the Quick filter (search) field in the Browser toolbar. Margin added for Qt6,
   due to right 6px the arrow is positioned exactly on the magnifying glass. The magnifying glass cannot be manipulated.*/
SearchLineEdit .QToolButton{
    color: white;
    margin: 0px 6px 2px 0px;
/* The buttons in the Quick filter (search) field in the Browser toolbar, mouse over. */
SearchLineEdit .QToolButton:hover{
    background-color: rgb(180, 180, 180);
    border: 1px solid rgb(120, 120, 120);
    color: black;
/* ActionPanel turns out to be only the Category Sets panel, and Batch convert, Actions tab. */
/* The bars in Category Sets panel and Batch convert, Actions tab.
   Margin so the bars fall inside the black border of the panel and not on it. */
ActionPanelHeader{
    margin: 3px;
/* The text in the light gray bars of Category Sets panel, not with Batch convert Actions tab. */
ActionPanelItem .QLabel{
/* The text in the bars of Batch convert, Actions tab, not with Category Sets panel. */
ConvertActionPanel ActionPanelHeader .QLabel{
/* The background of the added categories under the bars of Category Sets panel. */
/* This one does nothing anymore (used to). */
ActionPanelItem{
/* If all qtoolbuttons above are removed and .QToolbutton is placed behind ActionPanelItem
   then the arrows in Category Sets turn red.
   If the ActionPanelItem is removed, the background color changes. */
/* Text color between the bars in Batch convert, Actions tab. */
ConvertActionPanel .QLabel{
/* Discovered by searching for the word thumb in the exe. Background of all views of the browser,
   except the two with details. Previously inherited from QListView with background 140. The two selection
   lines added to eliminate the default blue color on the lables of a selected item which it inherits
   from Windows.*/
MyThumbListView{
    background-color: rgb(110, 110, 110);
    selection-background-color: rgb(80, 80, 80);
/* Newly discovered in the exe, only color works, the rest does not */
HistorySetPanel .QToolButton, SuggestedSetPanel .QToolButton, AssignedSetPanel .QToolButton{
    color: white;
    /* background-color: white;  */
    /* border: 1px solid rgb(250, 250, 250); */
