PDF thumbnail not in DIR thumbnail
MartinP
Post by MartinP »
I just updated to 12.2 from 10.x (forgot which one). So far I can say, it is quicker then before. The main issue I have is this: if you have PDF enabled to be displayed you could also see PDF thumbnails inside the thumbnail for a directory. with 12.2 you still have PDF thumbnails but not inside the thumbnail of a directory. So ig you only have PDF in a directory it now looks like it is empty.
Thanks an Cheers
Martin
Re: PDF thumbnail not in DIR thumbnail
Which filter do you use?
