I have some code tags entered in Settings>Viewer>Info to show things like Filename/Date taken/Dimensions etc. on the viewer screen.
But if I make any changes to these tags, after I click [OK] and go back to the viewer, all the info has gone. The only way I can get it to show again is to quit Xnview and restart, then the info shows correctly again.
Updating Viewer/Info field needs a restart before it takes effect
tbmmbt
