Hi
I was wondering if XnViewMP is affected by CVE-2026-111497, the brotli decoder vulnerability?
XnViewMP contains a file XnViewMP\AddOn\exiftool_files\lib\auto\IO\Compress\Brotli\Brotli.xs.dll which is likely a Brotli library.
Could an attacker use a file with modified EXIF content, to leverage this, to execute code?
Best regards,
Marius
Is XnViewMP affected by the brotli decoder vulnerability CVE-2026-111497?
mle86
Re: Is XnViewMP affected by the brotli decoder vulnerability CVE-2026-111497?
I'll checkmle86 wrote: Tue Oct 27, 2026 9:49 am I was wondering if XnViewMP is affected by CVE-2026-111497, the brotli decoder vulnerability?
No i don't think, exiftool uses his own libraryXnViewMP contains a file XnViewMP\AddOn\exiftool_files\lib\auto\IO\Compress\Brotli\Brotli.xs.dll which is likely a Brotli library.
