Skip files to catch up with buffer
evodoc
Post by evodoc »
When I view images that are large it can take to some time for the application to show it. I use the mouse wheel for previous/next image and at a harder scroll the app will flash the images one by one, causing several seconds lag. Would it be possible to somewhat get rid of this lag by skipping the inbetween files?
For example: I'm on 01.jpg, and I scroll which would end up 10.jpg. Let's say the app detects that it takes time over a certain treshold, so instead of flashing 02-09.jpg just jump to 10.jpg directly.
I'm on CachyOS using the TGZ if it matters.
