I’m running Linux CentOS 10 (a Red Hat derivative), and I’m unable to use NConvert to convert files to AVIF.
I can convert to other formats (jpg, webp, tga, png, etc.) but not AVIF.
Here is the code I’m using:
./nconvert -out avif -ratio -rtype lanczos -rflag decr -resize longest 1280 ./Tuxp.pngThe file is created but it is empty.** NCONVERT v7.300 (c) 1991–2026 Pierre-E Gougelet (30 July 2026/12:19:45) **
** This is freeware software (for non-commercial use)
Error: Don't know how to write this picture (./Tuxp.avif)
This is all the more puzzling as this command works perfectly well on Windows 10
To install NConvert, I simply downloaded and extracted NConvert-linux64.tgz. I’m running my tests in this folder.
It might be a silly mistake, but I can’t figure it out (I’m new to NConvert)
Many thanks in advance
