DNG 1.7 lossy: color error (RED too faint)
golemus
Post by golemus »
to reproduce this bug the following setting has to be enabled:
settings - format - read - camera RAW - view: Full size
(probably also Half size)
There are color errors, largest of them seems to be absence of RED channel. Or there is red, but much less than there should be.
E.g. if R pixel value should be 255 it is maybe 80 so it is not completely absent.
This is clearly visible in majority of sample images I provided earlier (link below). If you compare with DNG 1.4 version color is different.
https://nx76363.your-storageshare.de/s/MZiAbKDsda9bRK3
