Compile error [Delphi]
Post by Guest »
When i compile this piece of code, it raises an error:
  gflGetDefaultSaveParams(lp);
  lp.FormatIndex:=gflGetFormatIndexByName(Pchar('Tiff')); //Types of actual and formal var parameters must be identical
  e:=gflSaveBitmap(PChar('test.tiff'),gfl_bmp,lp);
Re: Compile error [Delphi]
Anonymous wrote:When i compile this piece of code, it raises an error:
Which error?
Post by Guest »
if you have
var
  gfl_bmp: : PGFL_BITMAP;
  sp: TGFL_SAVE_PARAMS;
then you must do
e := gflSaveBitmap(PChar('test.tiff'), gfl_bmp^, sp);
Don't forget the ^
Dimitris
Anonymous wrote:if you have
var
then you must do
Don't forget the ^
Dimitris
Sorry i don't understand. Where?
daremon
Post by daremon »
The original question was:
What is wrong with this:
e := gflSaveBitmap(PChar('test.tiff'), gfl_bmp, sp);
and i answered that the correct code should be
There is a symbol ^ after the variable gfl_bmp, which is needed by Delphi to dereference the pointer (something like * in C). That will solve the compile problem.
Dimitris
