Just wondering if there's an "argument" I can use to make XnView MP open a -copy- of a picture in another app. Perhaps some sort of "action chain"? (I'm using a phrase from the Calibre app but I think it conveys the gist of it.)
As an example: I have a raw photo (.rw2) I'd like to edit as a TIFF in Luminar. If I'm in Lightroom, the plugin Skylum provides makes a copy of the raw file (as a TIFF) and sends that TIFF over to Luminar. When the editing is done, Luminar returns the edited photo back to Lightroom where it is added to the catalog.
Even if I can only do the "make a TIFF copy and open it with Luminar" part, that's plenty. Obviously, the point of all this is to bid fare-thee-well to Lightroom.
Thanks for any suggestions!
Open a copy in another program?
jkm
Re: Open a copy in another program?
At this time, there's no built in multi-step action that can do something like that.
But there are a couple of ways you can achieve the result:
1. The simple way: In XnViewMP, Ctrl-C, Ctrl-V the image to duplicate it, then open the copy in your external app. (You define the app in "Configure Programs)
2. Use the "Configure Programs" functionality to script the kind of hand-off you want.
If you right-click on an image, you will see the Open With menu, and on that, there is "Configure Programs". This allows you to define a external program to hand the file off to. This can be a batch file or script for your OS.
In this script, you can make a copy of the file, and then call Luminar to open the copy, or you could even convert the file to a particular format using the converter of your choice, and then invoke Luminar against the result.
If you search the forums for "Open with" or "Configure Programs" you should find some examples of things people have done. Michel038 wrote an excellent tutorial on integrating exiftool to do things in this way that provides some examples:
viewtopic.php?p=183222#p183222
In his signature at the bottom of the post are links to other extensive tutorials he's done.
Hopefully this points you in the right direction...
