1.12.3: Ctrl and Alt keys now move slideshow forward (most likely affects all keys)
tikmok
Post by tikmok »
XnView MP 1.12.3 - 64-bit
OS: Windows 64-bit
The Ctrl and Alt keys, when pressed by themselves, now move the slideshow forward. This didn’t happen in previous versions, including 1.12.2.
Effect: Unexpected UI interaction. For example, if the slideshow is paused in full-screen mode, pressing Ctrl-Tab to bring up another window will move the slideshow forward.
1. Open a directory with multiple images.
2. Select multiple images.
3. Go to Tools > Slideshow > Enter.
4. Press <space> to pause.
5. Press Ctrl-Tab (or Ctrl or Alt).
Actual behaviour (bug): The slideshow moves forward. :bug:
Expected behaviour: Keys unrelated to the slideshow functionality shouldn’t move it forward—not Ctrl-Tab, Ctrl, or Alt.
Settings (Just in case):
bugreporter
Re: 1.12.3: Ctrl and Alt keys now move slideshow forward (most likely affects all keys)
Post by bugreporter »
Confirmed. And it happens with almost every key, unwantedly.
