PNG thumbnails inside directory thumbnail
MartinP
Post by MartinP »
Hi!
I found another change between 1.10.x and 1.12 (possibly also 1.11)
if you have a PNG with a transparent definition inside in a directory, the thumbnail of the PNG looks fine, but when used to be shown inside the directory thumbnail, it is black on black - it worked with 1.10
example images:
the thumbnail for the PNG is correct
inside the thumbnail of the directory, it is only black
Thanks & Regards
Martin
