Image import + XMP
cicciobello
Image import + XMP
Post by cicciobello »
I copied a directory with dozens of JPG files and related XMP files with ratings, descriptions, etc. onto my smartphone. XnView Mobile sees the directory, but does not see and does not use the XMP files.
Is it possible to make XnView Mobile use existing XMP files?
XnView Mobile 1.11 v91
Re: Image import + XMP
so you would like tu read the sidecar when browsing 'memory device/sd', right?
cicciobello
Yes, I would like XnView Mobile to read XMP sidecars created on the computer.
I copy the image files (including all associated XMP sidecars) into a directory on the smartphone (for example \DCIM\MyDirectory\, or \MyDir\), and I would like to find ratings, labels, etc. on the smartphone too.
