Exposure Compensation always shows "0 eV" in the Metadata panel
Bugs which are supposed to be fixed in the next test version (not available yet)
Peter_MM
Post by Peter_MM »
Hi Pierre,
I would like to report a metadata display issue in XnView MP regarding RAW files.
XnView MP Version: 1.12.3 [10346] - 64-bit
OS: Windows 11 (23H2)
Description of the issue:
In the compact visual Metadata panel (the summary box with camera/lens icons, aperture, shutter speed, ISO, and exposure compensation), the Exposure Compensation field always displays "0 eV", even when the photo was taken with positive or negative exposure bias.
However, when checking the list provided by ExifTool tab into the Info panel, the real Exposure Compensation value is read and displayed properly.
Tested cameras and formats:
• Fujifilm X-H2 (.RAF)
• Olympus E-M5 Mark II (.ORF)
• Nikon D7000 (.NEF)
Steps to reproduce:
1. Open a folder containing .RAF, .ORF, or .NEF files taken with exposure compensation different from 0 EV.
2. Select one of the RAW files in the browser.
3. Look at the compact Metadata panel: it displays 0 eV instead of the actual value shown in the Info > ExifTool tab.
I have linked (to my Drive) a sample RAW file from each camera (Fujifilm, Olympus, Nikon) taken with non-zero exposure compensation so you can inspect the tags:
https://drive.google.com/file/d/16_ebS2 ... drive_link
https://drive.google.com/file/d/1C2JLr2 ... drive_link
https://drive.google.com/file/d/1jk69um ... drive_link
Thank you very much for your work on XnView MP!
Best regards,
Peter
jkm
Re: Exposure Compensation always shows "0 eV" in the Metadata panel
Post by jkm »
Welcome to the forums, and thanks for the detailed description.
Obviously any inconsistency with Exiftool information interests me...
Unfortunately, the links you provided say access denied. Please provide unrestricted links or use a different service.
However I tested with some other images, and I can confirm the bug. I seem to remember this used to work correctly, so I think it was reintroduced at some point.
The problem is not just with RAW files. Even with jpegs the metadata panel is not displaying correctly.
It's also not limited to those cameras. It happens with every camera I've tested with.
I've supplied a link to an example image below.
Peter_MM wrote: Mon Nov 23, 2026 9:12 am ...the Info panel under the ExifTool tab...
Your nomenclature here is a bit confused. The bug is in the display of the Metadata Panel (as you correctly pointed out). The other panel is the Info Panel, and it has an EXIF tab (where the data is populated by internal logic) and an Exiftool tab (where the data is populated by Exiftool).
:bug: In the case of the example file (I assume it is the same for your files) the EXIF tab reads the "Exposure Bias Value" tag correctly. Also, Exiftool naturally reads the corresponding "Exposure Compensation" tag correctly. Both values are -1.7, but the Metadata panel shows 0. :bug:
So this is definitely a bug.
Sample image, -1.7EV
As I said I'm pretty sure this used to work correctly, but I had not noticed the regression. Thanks for raising this.
Peter_MM
Post by Peter_MM »
You’re right; the links I included below weren’t working due to an error. I’ve fixed them, and they are now working correctly.
Yes, the issue occurs with any type of image file format, but for me, it’s especially important in the case of the RAW format.
I believe I misspoke in my first message. The bug occurs where you point, in the panel that displays a summary of the metadata (labeled "Metadatos" in Spanish), which only shows the following fields:
At the top: ISO, f-number, shutter speed, exposure compensation (EV), and focal length.
Below: shooting mode, flash, exposure metering mode, etc.
There might be some confusion regarding the names of the panels, as I use the Spanish version of XnView, and the names may not correspond exactly to those in the English version. The issue occurs in the panel that displays a summary of the metadata (labeled "Metadatos" in Spanish), which shows only the following fields:
Top: ISO, F-number, Speed, EV bias, Focal length
Below: Shooting mode, Flash, Exposure metering mode, etc.
With that clarified, the bug I am reporting is exactly the same as the one you described. I hope it can be easily fixet in the next update.
Thank you for your answer and best regards,
Peter
Peter_MM
Post by Peter_MM »
Thank you for your work. It’s not common to respond and resolve issues so quickly.
Best regards,
Peter
Peter_MM wrote: Mon Nov 23, 2026 12:44 pm Thank you for your work. It’s not common to respond and resolve issues so quickly.
:D
