The new version of the program won't install
SergAxt
Post by SergAxt »
I have version 1.11.7 installed.
None of the subsequent updates will install.
I have no intention of updating Windows.
Is there a solution, or should I just accept it and forget about the updates?
Re: The new version of the program won't install
Windows 11? which build?
SergAxt
Post by SergAxt »
on www.xnview.com, you have 1.12.3 for windows 10
bugreporter
Post by bugreporter »
@Pierre: The russian error message above means, according to google AI:
"This program does not support the version of Windows your computer is running."
And Windows 10 Version 1607 is like ancient...
@SergAxt: Can't you upgrade to Win10 22H2, the last edition?
Of course, this is obviously NOT a bug.
