Personally, for "Gallery" view, I always select the "style" mosaic, but for all other views, I prefer the "style" list (with the name).
As a result, each time I switch from Gallery to Folders (or Device Memory, or SD card), I have to change also the default "style"
It would be great to be able to define a separate "default style" for each "views"
And it would be also very useful (even if less "critical") to do the same for other parameters of "Display" : "Sort" and "Group"
Be able to have default "Style" depending on "View"
LaurentG
