Hello together;
My Problem:
I take a Picture, make a doubleclick for fullscreen view.
Then i remove the Background and save it. The Picture changes but the preview stays as it was before the action.
Whatever i Try: no chance.
Is far as i see, the Problem is the embedded Preview in the Jpg-file.
I suspect the thumbnails are generated from the image's embedded thumbnail
and that thumbnail isn't regenerated when the image is saved.
As a result, the old thumbnail remains even though the image file has changed.
As shown in my Attachment.
When i save the Picture as "Copy of" then everything is as expected.
best wishes
Klauswr
Difference between Preview and Thumbnail
Klauswr
bugreporter
Re: Difference between Preview and Thumbnail
Welcome here - and yes, of course it has to do with the embedded EXIF thumbnail...
You either can delete this thumb out of the browser window (not viewer) by Metadata > Clean... > Remove ... and then only tick EXIF thumbnail. Or you set XnView not to use embedded thumbs at all, by Tools > Settings... (or F12) > Thumbnail and then untick "Use embedded thumbnail". Maybe you have to recreate thumbnails afterwards in Catalog > Maintenance > Maintenance... and appropriate options.
And this is definitely NOT a bug! It is how such metadata works.
I can reproduce
0. default settings
- ☑ 'Rebuild embedded EXIF thumbnail' is enabled (Settings>Format>Write>JPEG)
1. open any JPEG (24bit, w or w/o embedded thumbnail)
2. change to 8bit color or 32bit
3. modify image, eg rotate (no issue with resizing)
4. save as JPEG
it will be saved as 24bit - OK
thumbnail will not be updated
0. default settings
4. save as JPEG
