Black line artifact after converting to greyscale / 1.12.3 [10346]
meteorquake
Post by meteorquake »
In the attached, if you open it, ctrl-mousewheel zoom in and out it does as expected.
However if you change colour depth to Grayscale 256 (Dithering none) and zoom the same way, a black line appears at its bottom edge at various zooms. If you rotate the image 90 deg, the black line doesn't appear at the side but stays at the bottom.
My impression is that this black line is a screen artifact for the fileopen session.
1.12.3 [10346] 64bit Win11
d
Re: Black line artifact after converting to greyscale / 1.12.3 [10346]
