Preset 'Border' effects no longer working in 1.12.3
Steerpike
Post by Steerpike »
I had 1.10.5 installed, and preset Borders were working. I upgraded to 1.12.3 and they no longer work. Same with Mac and Windows versions.
Details / Examples.
Viewing an image pasted from clipboard (Shift+Ctrl+V), I go to 'Effects / Effects'. In 'presets', I've previously saved (eg) 'Border 2-2', 'Border 4-4', etc. Border 2-2 was created by choosing 'border' effect, then setting Frame 1 to black, 2 pixels, and Frame 2 to White, 2 pixels, then saving as 'Border 2-2'.
Before upgrading, those presets were working. Now, the presets are still present, but choosing them has no effect - I can choose Border 2-2, but Frame 1 is 10-point white and selected, Frame 2 is 0 pt black and not selected.
I can create a new preset - eg, 'Border 3-3', with frame 1 set to 3 and frame 2 set to 3; I can 'save' it, but when I come back to invoke it as a preset, the preset does not pull up the saved settings; it's back to 10-point white.
Interestingly, I also have several 'Blur more' presets, and they still work. So this bug is not affecting all presets. Since I currently only use 'blur more' and 'border', I can't say how extensive this issue is.
EDIT TO ADD: EXISTING Blur More presets worked, but when I created a new one (eg, Blur More, 30) and saved it, the name is saved but choosing it has no effect and the blur more slider is back to 0.
