Change Exif data: 'Date taken'
diablo
Post by diablo »
Can XnView change the Exif data that is put on .jpg files that was taken with a Lodak camera??? i need to change the date taken!!
if not can you make it is? to change the date taken?
Re: change the exif data (date taken)
diablo wrote:Can XnView change the Exif data that is put on .jpg files that was taken with a Kodak camera.??? i need to change the date taken!!
Currently you cannot modify EXIF data. Also I'm not quite sure whether it's technically possible and/or makes sense to change the EXIF date:
For all I know EXIF data is all technical data written by cameras.
For users there is the IPTC data. Perhaps IPTC data is the right thing for you?
