I'm working on a legacy system that uses nconvert.exe to resize some images for thumbnails. It does gif and jpg resizing great, no problems.
But now if I allow resizing an image with a *.jpeg extension, it does the resizing - BUT renames the extension of the finished image file with *.jpg
How can I prevent this? This of course breaks our image filenames. The following are the current set of parameters for the resizing job:
nconvert.exe -out jpeg -ratio -q 80 -dpi res_72 -resize 60 60 "c:\InetPub\Websiteinfo\ImageUploads\Thumbs\test.jpeg"
The finished file is renamed to "test.jpg" - how can I prevent this?
I've looked through the list of parameters from the sticky linked post - but it seems to be lacking any useful documentation. Is there a better place to look for more detailed docs?
Thank you.
Re: Prevent .jpeg resizing from renaming extension to .jpg
I'll add an optionScott Cadillac wrote:Hello,
Thank you.
Thank you, I appreciate that. Great little tool, by the way.xnview wrote: I'll add an option
