Hello!
I still have problems with EXIF and .cr2 files from Canon 350D. It seems like XnView miss something with Date Modified tag. And could that be why a lot of other labels in [MarkerNodes] are set to Unknown? The Owner name doesn't even have a value.
I've tried with XnView 1.82.1. In order to check that's it's not any errors in the cr2 files, I've opened it in photoshop and saved it as jpg and the Owner name now turns up, but photoshop strips a lot of EXIF data though.. :/
Anyway, I have 2 (3 with the photoshop jpg) example images if you want to try it out:
http://tempo.update.uu.se/~labero/EXIF/
best regards
Joel
EXIF and cr2 RAW files
Re: EXIF and cr2 RAW files
Ok, i check...LaBero wrote:Hello!
best regards
Joel
