- select few images
- choose "Strip of images" in menu
= focus should be on "Create", not "Cancel" IMO, same as in batch rename, convert...
Minor: Strip of images - wrong focus
Dreamer
ckit
Re: Minor: Strip of images - wrong focus
I've seen this problem when using "Batch Rename" and the "Overwite Dialog" appears with "Skip" which is just as annoying as "Cancel"Dreamer wrote: = focus should be on "Create", not "Cance" IMO, same as in batch rename, convert...
Just my opinion though.
Dreamer
Sorry, it should be another topic - split.ckit wrote:I've seen this problem when using "Batch Rename" and the "Overwite Dialog" appears with "Skip" which is just as annoying as "Cancel"Dreamer wrote: = focus should be on "Create", not "Cance" IMO, same as in batch rename, convert...
