GFLAX with DWG plugin
syntaxerror
Post by syntaxerror »
Is is possible to use with GFlax the CADImage plugin for displaying DWG DXF files ?
I have also noticed with GFlax v2.40 that .ai files are not supported anymore (used to work with earlier versions). Has anyone experienced same problem ?
Thanks for your answers
Regards
David
Re: GFLAX with DWG plugin
syntaxerror wrote:Hello,
It's not possible...
