Tabbed preview
Xyzzy
Tabbed preview
Post by Xyzzy »
xnview wrote:
Xyzzy wrote:
xnview wrote: Yes, will be added for EXIF/IPTC...
But please make preview appear in all tabs, not only Preview.
So not like Deluxe, Preview + Iptc/EXIF view?
Is there any reason NOT to put preview image there (I know a few for such solution)?
To supplement this feature:
- ability to disable tabs, with one selected type used as preview
- persistent tab selection between program sessions
X.
Re: Tabbed preview
Xyzzy wrote: Is there any reason NOT to put preview image there (I know a few for such solution)?
If you have preview + info window, the preview will be smaller. Which solution do you have?
Xyzzy
Post by Xyzzy »
Of course, it would be smaller, but it is better than none. Especially that you still could switch to traditional preview.
Theory aside, just look at this layout:
Image, displaying EXIF data at the side would be great.
X.
Xyzzy wrote:Of course, it would be smaller, but it is better than none. Especially that you still could switch to traditional preview.
But where do you put EXIF/IPTC info? Tab is an easy solution...
Xyzzy
Post by Xyzzy »
The only change to Deluxe version is addition of preview image to EXIF/IPTC/Properties tab- there is quite some free space there, and using it for preview image seems most natural.
The changes to Deluxe would be, as I wrote:
- adding preview image to tabs that don't contain it
- change of Preview tab to image-only tab, with no additional info (identical to current preview panel in XnView); Properties tab contains this info anyway
- ability to turn off tabs, with selecting one type (EXIF, IPTC, Properties, Preview) that would be displayed as preview panel.
X.
Xyzzy
Post by Xyzzy »
Here's the idea:
Of course only data is scrollable.
X.
