Changing thumb size crashes XnView
pdavit
Post by pdavit »
I'm using XnView v1.82 on WinXP Pro SP2 Eng.
My XnView crashes if while I have some thumbnails displayed I go to options -> thumbnails -> appearance and I user-define some custom size for the thumbnails.
Problem not present if I'm not displaying any thumbnails while configuring them.
I hate so much the fact that I adore women!
Re: Changinh thumb size crashes XnView
pdavit wrote:I'm using XnView v1.82 on WinXP Pro SP2 Eng.
I can't reproduce it, do you have enabled the cache?
ckit
Post by ckit »
Ok I can't reproduce your crash but I did find another type instead!
1. Open XnView in Browser mode
2. Go to Folder with lots of images in Thumbnails & Labels mode
3. Set Thumbnails to 128x96
4. Open Options -> Browser -> Thumbnail -> Appearance
5. Enable "Use Huge Thumbnails"
6. Choose any larger size than 128x96 -> Click OK
7. Now set XnView back to 128x96 and Crash!!!!
ckit wrote:Ok I can't reproduce your crash but I did find another type instead!
No crash for me :-( Do you have cache? do you have the crash in "Thumbnail" mode?
pdavit
Post by pdavit »
Yes I have cashing enabled.
The bug is not always reproducible. It looks like I have to stress XnView a little in order to get it.
What may help you is that after changing thumb size XnView starts redisplaying the thumbs, I get some
and then it crashes. This process looks like it's more of a read problem other than a display problem.
pdavit wrote:Yes I have cashing enabled.
Could you try with a clean cache? And without cache?
ckit
Post by ckit »
Ok, I disabled the cache and that fixed it.
pdavit
Post by pdavit »
This is a screenshot at the time of the crash: http://img225.imageshack.us/img225/6011/sst21nl.jpg
Disabling cashing has solved the problem here as well!
pdavit wrote:This is a screenshot at the time of the crash: http://img225.imageshack.us/img225/6011/sst21nl.jpg
If you have only some files, do you have the problem?
ckit
Post by ckit »
Ok, I just tried with only 7 files, cache enabled and there was no crash!
pdavit
Post by pdavit »
The folder on the screenshot I have supplied here contains 24 images with a total size of 2.5Mb that cannot be a real challeng for XnView. Average image size is 100kb and 24 is not that many.
The source of the problem is elsewhere in my opinion. Having said that it's quite impossible for me to reproduce the bug with a very small number of files.
pdavit wrote:The folder on the screenshot I have supplied here contains 24 images with a total size of 2.5Mb that cannot be a real challeng for XnView. Average image size is 100kb and 24 is not that many.
Very strange, do you have tested by removing cache folder before starting xnview?
pdavit
Post by pdavit »
xnview wrote:do you have tested by removing cache folder before starting xnview?
Sorry didn't get that!
Cache and tests---
—> pdavit
:) Hello Panos !
- There is a sub-directory so named <cache> in the programme-root…
Did you (re)move it before testing ?
- Here under XP-Pro according to your steps, I don't get any crash, the cache has his folder and is set, not cleared at all before testing, I didn't use a new INI, and I changed the size while a board of thumb-nails was displayed, no problem…
:mrgreen: Friendly,
pdavit
Post by pdavit »
Cleared the cache folder and problem still there only of course when caching is enabled.
