When performing two batch renames with different template names, the history in the drop down list contains the last template name, only.
Batch rename: History of templates does not work
In Batch rename, the history of templates is broken in 1.82.2:
Re: Batch rename: History of templates does not work
Right i'll fix ithelmut wrote:In Batch rename, the history of templates is broken in 1.82.2:
Chriss
If the bug has been fixed, it may have returned: In 1.92.1 Xnview does not seem to remember any Template History at all.
I have no problem with last version
Rename does not save templates
I have version 1.94.2 and it does not save Rename templates.
Even, I have edited manualy xnview.ini and when closing xnview all templates are erased.
Thanks.
Thanks.
Re: Rename does not save templates
Sorry, I refer to Batch Rename, after upload camera pictures, I select all and use a template to rename them in only one folder. Templates are not saved.Anonymous wrote:I have version 1.94.2 and it does not save Rename templates.
Thanks.
Thanks in advanced.
Sorry but i don't reproduce it, could you try with a clean .ini?Anonymous wrote: Sorry, I refer to Batch Rename, after upload camera pictures, I select all and use a template to rename them in only one folder. Templates are not saved.
I have tried deleting xnview.ini and when starting again I told to save ini in folder /Program files/Xview/ then I try to Batch Rename some pictures but after close and reopen it did not save any templates. In xnview.ini it is after [Rename] in Template# only Template0=name-# the rest is empty.xnview wrote:Sorry but i don't reproduce it, could you try with a clean .ini?Anonymous wrote: Sorry, I refer to Batch Rename, after upload camera pictures, I select all and use a template to rename them in only one folder. Templates are not saved.
I have tried to write my template in Template0 and Template1 but when closing xnview they are deleted.
I will repeat deleting ini and next time to save it outside of xnview program folder.
I tried saving xnview.ini in folder C:\Documents and Settings\user\Datos de programa\XnView but when closing program all templates are deleted.Anonymous wrote:I have tried deleting xnview.ini and when starting again I told to save ini in folder /Program files/Xview/ then I try to Batch Rename some pictures but after close and reopen it did not save any templates. In xnview.ini it is after [Rename] in Template# only Template0=name-# the rest is empty.xnview wrote:Sorry but i don't reproduce it, could you try with a clean .ini?Anonymous wrote: Sorry, I refer to Batch Rename, after upload camera pictures, I select all and use a template to rename them in only one folder. Templates are not saved.
I will keep trying to find about. Thanks.
Max Monroe
Max Monroe
Oh, gorram it... I know what it is.
The "Purge 'Most Recently Used Files & Directories' on exit" option under "Interface". If it's enabled, it helpfully erases rename template history too. If it's not, it doesn't.
Are you sure that this is intended behaviour though? I don't want to keep my history, but I would like to retain templates...
Right 'purge ....' delete history, so Delete or not???Max Monroe wrote:Oh, gorram it... I know what it is.
Max Monroe
I can see how this might be meant as a feature, not a bug, but honestly, "most recently used files and directories" does not suggest "...and templates too".
Even if this works as intended, as I said, I prefer not to keep history of files / directories I watch (yeah, I'm paranoid, I know...), but I do not consider rename templates privacy-related information.
Maybe this should be a feature request then: I'd like to keep template history, but not file/folder history (and apparently so do a few other people). Could this be perhaps another checkbox please...?
Max Monroe
I'm not saying anyone explicitly requested that before.
All I'm saying is that I'd like to request this now.
Seeing as how other people were fooled by the same feature (checking "purge..." but not expecting their template history to disappear - the reason this post exists at all), I imagined they would like such a feature too...
