XnView / GFLAx is exactly what i'm looking for... i want to be able to upload an eps file to my webserver and have asp convert the eps to a jpg thumbnail so i can send a thumbnailed file listing to the user's browser.
The pages all say that GFLAx will do the trick, but i can't find any documentation on how to use the COM object. i've searched the forums a few times, but there doesn't seem to be any object reference material.
Any help yould be greatly appreciated!
Thx,
airyt
SDK / GFLAx Documentation
airyt
Can't load EPS file
Hello, So i've done lots and lots of searching...
I have downloaded and installed:
AFPL Ghostscript (8.53) from http://www.cs.wisc.edu/~ghost/doc/AFPL/
GflAX DLL 2.23- GFL 2.40 (Standard)
I am running Windows 2000 Server w/ IIS v5 and ASP v3.0
I am trying to read an EPS file and convert it to a JPG thumbnail. I continually get the following error:
from the following code:
Can you please help? I have restarted the computer many times. Rebooting does not fix the error.
Is there any other way of testing whether or not the GFLAx object is interfacing with GhostScript properly?
Is there a well-known version of GFLAx and/or GhostScript to accomplish this task?
Thanks in advance!
airyt
GflAx.GflAx.1 error '80004005'
Error to open file
/temp.asp, line 22 Code: Select all
Dim oImage
Set oImage = Server.CreateObject("GflAx.GflAx")
strSourcePath = Server.MapPath( "images/sy.eps" )
strTargetPath = Server.MapPath( "images/sy.jpg" )
' Response.Write( "Convert " & strSourcePath & " -> " & strTargetPath & "<p>" )
With oImage
.epsWidth = 3000
.epsHeight = 3000
.epsDpi = 60
.EnableLZW = True
.LoadBitmap strSourcePath
.SaveFormatName = "jpeg"
.SaveBitmap strTargetPath
end with
Set oImage = Nothing Is there any other way of testing whether or not the GFLAx object is interfacing with GhostScript properly?
Thanks in advance!
airyt
Re: Can't load EPS file
Do you open your eps file with XnView?airyt wrote:Hello, So i've done lots and lots of searching...
from the following code:Code: Select all
GflAx.GflAx.1 error '80004005' Error to open file /temp.asp, line 22Can you please help? I have restarted the computer many times. Rebooting does not fix the error.Code: Select all
Dim oImage Set oImage = Server.CreateObject("GflAx.GflAx") strSourcePath = Server.MapPath( "images/sy.eps" ) strTargetPath = Server.MapPath( "images/sy.jpg" ) ' Response.Write( "Convert " & strSourcePath & " -> " & strTargetPath & "<p>" ) With oImage .epsWidth = 3000 .epsHeight = 3000 .epsDpi = 60 .EnableLZW = True .LoadBitmap strSourcePath .SaveFormatName = "jpeg" .SaveBitmap strTargetPath end with Set oImage = Nothing
Thanks in advance!
airyt
Yes. No problems there apparently. Although one of the AI files looks funny.xnview wrote:Do you open your eps file with XnView?
Note: i have tried successfully to get this to work with other file formats (jpg, gif).
Is there a certain directory that GS must be installed in?
I found out what the error is...
You MUST allow the IUSR_<machinename> account to have read & write access on
%SystemDir%\Temp\
It appear the GS will create a temp file in this directory when doing it's thing (as the internet user) and if there is no write permissions, this function will fail, thereby screwing up the conversion.
So for me, i simply gave IUSR_<machinename> full control over C:\WINNT\Temp\
Hope this helps someone else!!
%SystemDir%\Temp\
