Send by e-mail does not work (Outlook 2003)
Rodho
Post by Rodho »
I can't send picture by e-mail :(
I use the latest version of XnView
I use Outlook 2003, Windows XP Home
Thank you!
mcwolf
The same problem
Post by mcwolf »
I can only send one picture at the same time.
When i have two or more pictures selected i can't send them.
Xnview 1.82.2
Outlook 2000
XP Home
Thanks!
Wolfgang
Olivier_G
Post by Olivier_G »
I tried it: it worked perfectly for me (Win XP + Outlook express)... by first opening an XnView window with various options before launching the Outlook Express' usual Message window with all elements.
Olivier
No problem here
:) Hello !
- It works like a charm here too with 1.82.2 - XP-Pro SP1 and Eudora 6.2.1.2.
- I sent five images as one go to the same recipient…
:mrgreen: Kind regards,
Georg_tc
Same problem with Outlook 2003 here
Post by Georg_tc »
I just upgraded to 1.82.3.
Posting ONE image works quite good with Outlook 2003. I don't even
have to type in a email address, because it creates a new Outlook "Send" window, and then I can choose an email address from the Outlook address book. :-)
BUT: If you select more than one picture in XNview, nothing happens at all :(
Kind Regards
Georg
Re: Same problem with Outlook 2003 here
Georg_tc wrote:Hi,
Ok, so the problem with Outlook 2003 is with more than one picture??
qs
Post by qs »
I have the same problem with latest XnView 1.82.3. I can not send multiple pictures by email whilst it works with only one picture selected.
I have Windows XP with Outlook (not Express) 2002.
qs wrote:I have the same problem with latest XnView 1.82.3. I can not send multiple pictures by email whilst it works with only one picture selected.
Someone who has no problem with Outlook and more than 1 pictures?
Gyro
Post by Gyro »
Hi everybody.
I had the exact same problem using Microsoft Outlook (not Express) with Windows XP.
I just downloaded Mozilla Thunderbird and it DOES WORK!!! I use Mozilla FireFox instead of Internet Explorer so why not go to Thunderbird for my e-mail client. The only thing I don't like about Thunderbird over Outlook is that it does not have a calendar.
-Gyro
Frank
Post by Frank »
Hello!
I also cannot sent more than one picture at the same time with Outlook 2003. Is their a plan to fix this function?
Frank wrote:Hello!
I'll try to fix, i have not outlook 2003 so it's a litlle difficult...
xnview wrote:
Frank wrote:Hello!
It's not just Outlook 2003, the problem occurs in Outlook 2000, too.
helmut wrote:
xnview wrote:
Frank wrote:Hello!
So the problem is Outlook.... :-)
Post by Guest »
So it is!
