command line slideshow effects not working
gstoyanov
Post by gstoyanov »
I have just tryied to create a slideshow from CD. I have selected "All effects" for transition effect. In the file there is a value "Effect = 2", which (after I played a while) seems to be correct. However XnView always shows only one effect (slide from right to the left).
The command to start XnView was:
K:\>.\xnview\xnview.exe -slide "Show.sld"
where "K:" was CD drive.
Opening the file "Show.sld" from XnView has the same problem.
However, when creating a new slideshow (whitout saving it) and then pressing "GO" button - everything is working as expected.
marsh
Post by marsh »
Confirmed. Same problem with associated sld files.
The only effect I see is left to right for 'all effects'.
Re: command line slideshow effects not working
gstoyanov wrote:I have just tryied to create a slideshow from CD. I have selected "All effects" for transition effect. In the file there is a value "Effect = 2", which (after I played a while) seems to be correct. However XnView always shows only one effect (slide from right to the left).
Right, i'll fix it
