i have a Folder containing shortcuts (.lnk) of pictures. Ist it possible to print the pictures corresponding to the shortcuts in a batch? My only solution is to open every single picture to print it out.
Print Folder with Shortcuts (.lnk)
Re: Print Folder with Shortcuts (.lnk)
In the browser, if you select your .lnk, print failed?Virtuo wrote:Hello,
