Caching images on CD Roms
Post by Guest »
helmut wrote: Topic 'Always reload thumbnails'
In XnView a so called cache is available which can hold a copy of the thumbnails for fast display.
Is it possible to create a cache with relative file-names / paths?
My idea is the following: I would like to archive all my jpgs on CD-Rom, and I would like to use the cache and save it to the CD-Rom as well.
My Problem: The cache seems to use fixed path-names, so the CD-Rom (having a different drive name, e.g. d:\ vs. c:\my_temp_pictures\) will not make use of the cache (except for when I look at the pictures a second time, but that is not what I want).
Said differently: Can I save my pictures on CD-Rom and include a cache which will speed up the first display of the thumbnails of the pictures (no matter on which computer (or even OS) I look at the CD-Rom)?
Re: Always reload thumbnails
Anonymous wrote:Is it possible to create a cache with relative file-names / paths?
My idea is the following: I would like to archive all my jpgs on CD-Rom, and I would like to use the cache and save it to the CD-Rom as well. ...
I do understand your idea, but cached files per directory is not supported in XnView.
This might be a useful enhancement/option. But then it must be ensured that future XnView versions are still able to read the cache file.
Post by Guest »
thanks for your reply.
"relative-path"-caches (or whatever you would like to call them) seem to be a very useful feature, and I hope this will possible in a future version of Xnview. It would appear to me that this should be not too difficult to implement.
Thanks once more,
Thomas
crazytb
Post by crazytb »
If possible, the relative cache should be compatible with other image viewers. As far as I know, each viewer (Thumbs Plus, XV, Gimp, any other) has its particular way of storing thumbnail caches. The heaven should be a place where any of these programs could read any format. I know, it is almost impossible to do, but if XnView can read some formats from other applications, it will be one step to heaven! :) :D
