Cache does not see change in 'embedded' setting
marsh
Post by marsh »
The cache will not acknowledge setting change of [ ]Use embedded thumbnail.
If you turn "use embedded" off, the cache will still use embedded thumbnail even if picture has been cropped.
v.1.80.3 does not do this.
Re: Cache does not see change in 'embedded' setting
marsh wrote:The cache will not acknowledge setting change of [ ]Use embedded thumbnail.
Yes, you must clean the cache...
