Column "Folder" in <Search results>
brotondi
Post by brotondi »
... would help to have some overview...
Bruno
Re: Column "Folder" in <Search results>
brotondi wrote:... would help to have some overview...
For what?
brotondi
Post by brotondi »
Hi Pierre
Since I still use MS Explorer for these needs (also the other Topic): Do not invest Time you could use elsewhere, except it is fast done or other people will add a "Yes, please do that" in the topic.
For what I use this: i.e. I downloaded the Hubble-Gallery, and wanted to see the Files. XnView has this new View-Style "Thumbnail + File Infos" which is better than the only "Thumbnail" from MS Explorer, but in XnView I cannot see in which Folder the Result was... So I still use MS Explorer, write a little Programm to analyse, rename, move and then go Back to XnView to have fun with the Pictures...
Have a nice Day!
Bruno
Xyzzy
Post by Xyzzy »
Tootip displays filename with path.
X.
Dreamer
Post by Dreamer »
So you need just "path" there? I think there is already a request for this, but I cannot find it...
Not all users use tooltips, it's a bit annoying, so I support this request.
